Ok I will apply 4.5 cm horizontal offset on both tweeter and midrange.
Can you also move the drivers up by 2mm (90mm tweeter center to baffle top)? That's very little, and it will probably have almost no effect on the acoustics, but it would be nice to get the golden ratio in there.
Also, the 22mm baffle will require some extra machining to mount the Volt dome flush with the front. 19mm would be easier. But again, this will have zero effect on the Leap model.
Have you thought of doing a simulation with the mid and tweeter offset also? Here is a review of the Volt that may give some info.
Test Bench: Volt Loudspeakers VM752 3” Midrange Dome Driver | audioXpress
Strange in the Audio Express measurement of the Volt VM752, that there is also SPL fall off below 1 kHz off axis...
Maybe because it is measured in an enclosure and not on a large IEC baffle.
I don't understand it.
The Faital is available almost worldwide, the DAS is available only in Europe?
Should we take availability into account?
First thing this morning I received an email with a quote for the DAS driver from the Swiss distributor. These guys are quick! If there is a dedicated distributor in Switzerland, they might as well have distributors in other, larger countries. I will ask them, but I guess availability is not as much an issue as one might think.
Oh, the price in the quote was CHF 180.- for one unit, including VAT and shipping. That is slightly more than what I have seen in some online shops outside of Switzerland, but I believe it's still a little bit less than the Faital (not that I would care, though).
^^ Yes it looks strange. ATC and PMC use similar dome that is no longer available for diy. It has been measured by many others
ATC-SM75-150
ATC SM75-150S Dome Mid Measurement Data
http://studio-hifi.com/images/ATC75-150S_JeffBagby.pdf
from Gravesen:
ATC-SM75-150
from Gravesen:
D.A.S. Audio have a rather long list of distributors around the world:
Distributors | D.A.S. Audio
Easy.
As an information, the horizontal off axis responses on infinite baffle of the tweeter Satori TW29BN and the ATC SM75 3 inch midrange. The responses are normalized to the on axis response.
In both plots the measured data and the Leap simulations to compare. The datasheet curves for the Satori and Troels' measurements of the ATC (post #85). The Leap curves are the more solid curves.
For the Satori tweeter the 30 and 60 deg data is shown and for the ATC midrange the 20 and 40 deg responses.
You can see that for the tweeter the Leap model is matching, for the ATC there is some difference with the Leap 3 inch model, maybe because of the missing waveguide in the Leap model.
We will see what we can be done about it, also with own Volt measurements. To do a first study now, I will use these current Leap models.
Very useful again!
I attached a plot of my own measurements of the ATC SM75-150 (centered on a 23cm wide baffle, and also with 13cm baffle extensions on both sides). The measurements were made with an electronic high pass filter (24 dB/oct, 360 Hz). Looks like the waveguide achieves constant directivity up to about 3 kHz. Maybe that's useful.
Yes it is constant directivity up to 3 kHz, I also see in Leap by comparing the SPL on axis and power response of the Volt VM752 in the Monkey Box. In attach the plot, SPL in red and power in blue. Technically this is a real top driver.
Looking to your ATC measurements, I understand now why the SPL off axis is lower below 1 kHz in the AudioXpress measurements. It is because it is placed in an enclosure and not on a large baffle. I see the same in the Leap simulation.
AudioXpress mounted the driver in an enclosure with a baflle of 28 x 43 cm, I suppose 28 cm wide.Matthias used 23cm baffle, this project will be something like 43cm...
In attach, the SPL on and off axis 0 30 60 degrees of the Volt VM752 in the Monkey Box simulated in Leap.
Looking at your plot I'd say that an x-over to the tweeter at about 2.5 kHz would make sense -- what do you guys think?
I was calculating with 35cm internal width. So ca. 38,7cm with 18mm material.
Edit:
What did you go with in your sim Paul?
In Leap the internal volume can be chosen independent of the external dimensions of the cabinet. I have chosen 70 L now.
I did choose the dimensions of the front 38 x 78 cm as a function of the driver dimensions. And did a rough estimation of the depth for a netto internal volume of 70 - 80 L.
I have not calculated yet excatly. I used 22mm for the walls and 30mm for the front as a first shot .
I will do a simulation with the final dimensions later, that is no problem.
The final dimensions, we have to do together of course...
Yes that is exactly what I thought also . And probably you don't need a tweeter waveguide, looking to the polar diagram.
Polar diagram of Volt in Monkey in attach. Remark: with the current Volt VM752 Leap model, which is not 100% correct off axis, see previous posts... The driver responses in the cabinet are ready, so X-over can be designed. What should it be?
The driver responses in the cabinet are ready, so X-over can be designed. What must it be?
I'd suggest trying a 1st order filters between mid and tweeter because they behave very well in the time domain and sound good if the drivers are clean enough in the x-over range (at least to my ears). See also here.
The woofer/mid x-over should not be lower than 400 Hz, maybe a little bit higher to avoid loading the mid too much (500 Hz?). The filter slopes should be a bit steeper (2nd order?) to avoid the woofer from doing too much in the midrange.
In general I'd suggest to apply full impedance compensation so that the filters see a flatish impedance. For sure, the huge impedance peak of the Volt dome will need compensation to make the high-pass for the Volt dome work. But I guess going all the way by compensating also the tweeter resonance peak and the (upper) woofer resonance peak is a good thing. Same goes for the impedance rise due to the voice coil impedance. This means a bunch of extra parts, but they are a good investment in my experience (and they don't need to be expensive super-duper parts).
Does anyone have the voice coil inductance of the DAS 12P?
Paul:
Was that internal or external dimensions? Including vent?
For the simulation I have chosen 70 L netto exclusive the vent.
With the current dimensions of the cabinet model, and taken 22mm for walls and 30mm for front panel, the netto internal volume is 86 L now, exclusive vent, inclusive optional bracing and inclusive volume occupied by drivers.
The cabinet can be made smaller (less deep maybe). Or some more volume than 70 L can be used.
Here are the simulation results of the drivers in the cabinet.
I have added also the frd files for X-over experimenting.
As an information, to realize a F3 = 45 Hz the SPL should be designed at 91.2 dB (full space).
- Open Source Monkey Box
