OpAmp driven diamond buffer amplifier
Hi njswede,
That's cool. Now, later build it using good parts, 2 EF output stage. Look at the Nakamichi 620 amplifier or the Marantz 300DC for inspiration. There are other amplifiers out there using a similar output configuration. They all sound great and have good reputations.
Those types are selected for their linearity and consistency between devices. To get performance there are times you need to use parts intended for higher power applications. Also try NJW0281 and NJW0302. Don't use a TL072 or 071, try NE5534 or NE5532, an LM4562 is probably going to be the pinnacle of performance but I'm not sure how much better the entire circuit would be over the NE553x series. An NE5534A will perform better than the NE5532A on paper, but make sure you buy the TI version, not something unknown from a non-authorized distributor.
Yup, I just ballparked it in my head. 0.7071 ~ 0.7. Right now the question is more distortion performance. Power, that's just voltage. I've built many up to around 100 wpc, so performance should be quite good. Commercial examples are held in high regard from what I have seen. I have a couple examples of models that are diamond buffer designs for reference. Nothing better than looking at successful examples.
The real plus is the extremely linear output stage. The negative is supplying high peak currents to the load as it may current limit. Depends on how you drive it.
Yeah, I think there’s some improvements I can make on the build, including (but not limited to) better parts. 🤣
But it was a very successful proof of concept.
Reactions: lene and anatech
With peak voltage of 16V, P=V*V/(2*R), power would be 16W.
It's a bipolar supply. I'm running the prototype on +-18V, so I'm getting about maybe 14V peak, which translates to about 25W peak across 8ohm. The swing is still a bit anemic, but I don't think I can fix that without adding transistors, and the whole point was low component count.
If we're arguing the distinction between peak power and the power delivered when a sine wave is driven to threshold of clipping, I agree completely.
But If I'm not mistaken, common practice is to specify power (and distortion) when driven by a sine wave. I remember when "peak music power" was castigated as advertising hype. 😉
Hi No ideas,
I am missing what you are getting at. Those two are vastly different transistors, nowhere even close. One is a driver or Vas, the other an output or driver for a high current output stage.
Can you rephrase your question?
You would typically use the same drivers in each channel, and the same outputs. But since they operate independently of each other you could use whatever you want in each channel as long as they were appropriate for the job. The channels would probably differ in performance, but they would work.
As soon as I verified that the PCB design isn’t completely bonkers, I’ll post all the CAD and simulation files on GitHub (like I do with all my projects). You should be able to tweak the layout very easily to allow any component footprint.
