I was thinking of using the BLH cabinet from Fostex.Depends what sort of horn you're thinking of. Broadly speaking, 'no', technically speaking in most cases 'no', but depending on context and within a limited application & what you're trying to achieve -'yes'.
Enclosure: P1000-BH - Back-loaded Horn Enclosure Box for P1000K | Speaker Components| Fostex
I have a pair, so was thinking of trying it out there...
Oon
Fostex horns were designed for the FOstex drivers and have proven to be mediorc3 to poor.nandappe’s suggested horn looks like a semi-random nagaoka box choosen becaue it used some other 4”.
If you are going to try a random horn the FH3 likely offers the best chance of success and is much more tuneable.
dave
dave
You forgot to consider the possibility that I am an incompetent carpenter... and I live in a pretty small place. This is just for the sake of fun. Just going to stuff this in whatever 4" box I have available.... [emoji6]Fostex horns were designed for the FOstex drivers and have proven to be mediorc3 to poor.nandappe’s suggested horn looks like a semi-random nagaoka box choosen becaue it used some other 4”.
dave
Oon
I can't read Japanese but from what I understand from all the reviews, they show the speaker not the book. I think it is a situation where you buy the magazine, free the speaker driver. ...Firstly is where can we order a pair wonder if Amazon does include the speakers or just the book as its not clearly stated
In the following month version, you buy the magazine, free the double reflex box flat pack... strange but interesting way of selling things.. Normally happens to kid educational toys only. Maybe someone who understands Japanese can confirm this...
Amazon.co.jp
Oon
The Mook projects are normally a yearly event; the idea as I understand it was that you got a book / magazine with a pair of drivers. The book was sometimes in the form of a simple flat-pack you could put together and stick the drivers in, with extra plans / designs provided. Markaudio did the drivers for the past couple of years, and some of the extra designs were actually done by little old me; Onkyo as you can see were the supplier this year, but I assume the basic principle is the same. I don't know for certain though, so please don't take that as definitive.
I have not measure but Tabaq fits nicely
with small foot print and easy build.
TABAQ TL for Tang Band
Double reflex box flatpack is not really recommended because it's very thin MDF.
Hi Tamra,I have not measure but Tabaq fits nicely
I noticed you are Japanese... need your help. Did we interpret the amazon japan website correctly. Buy book, free speaker?
Oon
This should be the book with speakers: Amazon.co.jp
This should be the book with a flatpack: Amazon.co.jp
Am I correct?
Am I correct?
pelanj, you are correct.
First Amazon link sells a magazine with an included pair of Onkyo full-range drivers, second link sells a magazine with flat-pack double-bass reflex enclosure which is compatible with the Onkyo full-range drivers.
Note that the enclosure can be built as either a double-bass reflex or a conventional single-port bass reflex.
I bought the driver, but unlikely I will build the enclosure... not competent in carpentry. Most likely will go into my Fostex P 1000 BH cabinet.If you buy driver,there are 5 enclosure plans in book.
Oon
- Full Range
- ONKYO 10cm Full Range Speaker Project from magazine appendix Year 2021
