(one more) ALEPH P 1.7 clone
Landoctor said:
transformers
Donovan,
can't help you there, i don't know of any online sources for transformer cores/bobbins.
If you are referring to split bobbin types, such transformers used to be very common for diy assembly transformers.
There's an electronics (surplus) store in any direction overhere, diy electronics has a long tradition in these parts. (likely the reason for the large number of cheese/sauerkraut flag members present at this forum)
I buy bulk materials every time i visit a surplus store and see an interesting offer.
Cheap brands totally wrecked the transformer market, overhere that started ~20 years ago with Altai and Monacor junk quality products.
A 120VCT/60VAC in parallel split bobbin type can be ordered from Allied Electronics in Texas.
A choice of 56VA to 100VA, between $15 and $25.
Allied Elec. carries transformers by Zettler from California(not relays from Germany), Hammond from Canada, Triad from China.
Zettler manufactures the prettiest ones but only to 20VA, a 120VCT/60VA Hammond would be a nice choice, about $20/pc.
No idea what the Triads are like, Triad Magnetics does seem to make pretty good ones for tube gear.
Split bobbin types can be ordered direct from Zettler, the $25 minimum order is good for four 20VA transformers.
(double C-core split bobbin transformers are tops, unfortunately the prices are scary)
Re: Jacco
tryonziess said:
You just saved me some serious money. Thanks a bunch. How about output transformers for solid state amps. Can not seem to find many of them. Tad
You're not kidding, big price savings on those transformers. Now if I can only find decent film caps for less than an arm and a leg.
Same problem here...
Guess the polish post order company is messing up a bit at the moment. He uses usps. He send me a picture of the shipping bill and did a reclamation of my order two weeks ago.. haven’t heard anything ever since.. he's probably out of town or something like that.
C.
tryonziess said:
THIS IS
Toroidals have become the universal transformers, read as easiest to obtain.
Their combination of a small and single direction concentrated stray field, very high peak output power and good regulation makes them the obvious (economical) choice for power amplifiers.
Those factors are of insignificant importance for the powersupply of a pre-amplifier.
A pre-amp powersupply has a constant powerdraw, peak output capability of the transformer is of no importance.
Pre-amp circuits employ regulated rail voltages, in contrast to most powersupplies of power amp output stages.
That makes the transformer regulation factor irrelevant for pre-amp use.
(click the comparison button at the link above for more items)
A direct result of the donut core design feature is a very high bandwidth, every piece of garbage that enters through the mains exits the other end of the transformer.
Winding primary and secondary on top of eachother makes it worse.
The single important feature a delicate pre-amp circuit desires is being fed by the cleanest power.
A block type transformer has a built-in bandwidth limitation, physically split windings ensure that the core filters out the bulk of the junk that enters.
The price difference between a toroidal and a traditional tranny can add a mains filter to the beloved audio project.(a single buck sometimes buys a used fancy Swiss made that does +$15 new)
Damian may have a busy semester at Polakski-U, the eye candy he sent me only took a couple of days to arrive.
It looks llike Posts are a big problem all around the world.
I received the Aleph P PCB's from Poland in more or less 10 days.
On the other side i have been waiting for more than one month for the Firstwatt F3 PCB's from Canada and there are no news.
I know that they have been sent a the beginning of September but i did not receive them yet...
Jacco
You have this most incredible library of parts suppliers I have every seen. Those Japanese transformers are sweet. They probably carry a serious price tag too.
I took your advice and ordered the split bobbin Hammond tranny from Allied Electronics. I also very much appreciate all of the fine input. Now where are you going to use that toy from Damien. Tad
