One (1!!) transistor clapping...
keyne said:
the transformer needs to cope with 800mA DC - no go with a mains trannie. unless you have another winding and put a compensating current through this. (but then of course you have more active devices), yes like in schematic no. 3 on bonavolta's page. i think that looks like a very interesting amp...
transformer coupled transistor amps are rare..
my new preamp has an output transformer..
so why not a nice efficient SE amp with tx coupling for my horns..
regards
keyne
How about putting a cap in series with the output transformer primary, and in parallel run a low-resistance choke from supply to the drain? That would let you use a standard power toroid and a choke, no extra devices?
Jan Didden
Hey Jan,
what you describe is "parafeed" in the valve world.
the coupling C can be made smaller than without a step-down transformer.
i think this is interesting for my horn setup which only has to do 60Hz + . So i don't need to massively oversize the transformer to cope with low bass. This might lead to better HF characteristics of the transformer.
regards,
keyne
Have you looked at this?
http://www.tubecad.com/page11.html
http://www.tubecad.com/page12.html
I do not know if any of these amps have alredy been build and listened to - but well worth a try if somebody can calculate (and make...) suitable chokes.
Pathos is using the "inpol" circuit for a long time, the output section is a follower. The schematic was posted here before.
Klaus
tom-vdl: That schematic you posted is pretty much the same as I have in mind. What would happen if we put a zener diode across that 47uF cap to stabilize the bias voltage? I know that it is an active device, but it wouldn´t be directly in the signal path.
And by the way I don´t see any feedback, you must havea log of gain in that circuit?
lohk: Choke loaded source followers are excellent output stages in my opinion but the have one major drawback: they need a separate gainstage.
keyne said:
Hey Jan,
regards,
keyne
So I invented parafeed?? Again?? What the heck!😉
Jan Didden
Fuling,
about the zener diode:
That will take care of drift caused by any variations in the mains voltage. However, you will have to replace the 250k pot by a normal resistor and the 390k resistor by a pot else it is not possible to set the quiescence current. I have thought about using a zener as you suggested, but I would rather have a solution that will take care of the thermal drift as well.
About gain:
As Steve Eddy pointed out there is a source resistor and that makes the gain of the amp approximately RL/0.33 where RL is the speaker load. As a speaker is a frequency dependent load gain will normally vary with frequency. Fortunately I have loudspeakers with a quite flat impedance curve.
Tom van der Laan
P.S. Just some information. The cutoff frequency for a given load and inductance is given by: Fc = RL / (2*PI*L)
Steve: That is ultimate simplicity!
Unfortunately stepup transformers tends to have crappy frequency response, at least if the ratio is bigger than 1:3 or something like that.
Tom: Current feedback, then?
What about a slightly higher value on that source resistor, that should take care of the thermal drift, right? Of course it would lower the gain, but maybe not too much?
Fuling,
About a bigger source resistor:
You are right about that. A larger resistor will reduce thermal drift and a bit of thermal drift is not a problem. Using a larger source resistor will also boost the output impedance. However in my case that might not be such bad thing as I have recently switched to open baffle speakers. The higher output impedance might give me a bit more low frequency response. I think I will try it this weekend.
I wished I had discovered these tubecad pages before. They are great. Just one thing that I was wondering about. How do they set the bias current. With the low DC resistance of the inductor I think the feedback network in the amps is not going to work properly (at least not for DC).
Tom
