Oh no...not another Baby Huey EL84 build.
Hi Bas,
while looking at other BH84 to compare with what I'm doing, I just noticed that you used higher wattage than suggested on R7 and R8. That is exactly what I noticed after having soldered them. Based on my experience on guitar amps, plate resistors do improve dynamics when they have higher wattage than standard 500 mW. Is it your experience too in Hi-Fi?
Thank you in advance.
Roberto
Roberto,
I hope Bas will reply re. R7 & R8 on his views of these resistors. Interesting that you noticed better dynamics with higher watt resistors. Ian (gingetube) suggested that these be >1 watt resistors, if I remember correctly, to handle the high voltage across them comfortably.
Yes, Joule-Thomson noise is lower, but in mainly in EL34 amps is due max voltage (1/2 W resistors are rated for 350 V only across them). In EL84 would not be strictly needed (I squared x R is 100 mW, and dV is less than 250V), but I will report the differences if any.
Hi all
I am building this EL84 kit for a friend using Parsi's boards. I have started soldering according to BOM posted, but there are some difference on printed values on PCB and BOM.
R,20,R21 1M ,
PCB 470k
R18 : 680R
PCB : 1k
R39 : 33k
PCB : 15k
R16 : 15k
PCB 1.6k
R17 : 10k
PCB :1k
Can anyone confirm whether I should go ahead according to BOM and ignore printed values on PCB?
Sachin
@ Bas :
Browsed very carefully (I thought 🙂 ) this thread and could not find a hint which manufacturer
you are using for your PCB's. Can you supply this info please
And......indeed as a lot of members already wrote: you did a great job. Respect!
Joe.
