yea, I looked at 450w app, since I wanted more then that. I will make my own heatsink, won't buy ready made
I just do not know how to make that Transformer, it seems pretty complex...
But That can be overcome too.
do you have any way to measure inductance? If you do, its pretty simple, but like I said, books... you can calculate... in any case you can oversize those things, and have no worries. Just note that on PFC you will need gap, on smps not
You can always find someone to build it for you, just give them core and specs... or just specs, really depends who you find
Yes I can measure HCR, with a cheapo meter I bought on EBay for 10 bucks...
Works okay, close enough for me anyway...
What would you guess at the cost of the Transformer? How long would it take to get it...
to get it made? I would guess a lot more then diy, you would get is pretty fast I think, say 1-3 weeks, but I also have no idea... you should ask and see what they'll sayYes I can measure HCR, with a cheapo meter I bought on EBay for 10 bucks...
I take 400v and 2-3A over low voltage and 400A anytime, nothing to be scared, not like you will touch high voltage 😀This is dangerous stuff, I guess I need about 2 or 3 amps @ 400 volts😱
hi krisfr,
why not go for some simple supply first then go for upgrade.i myself also wanted to add pfc
in front end.
regards
ravs
be a vegeterian......
in front end.
regards
ravs
The circuit itself is simple in a sense...but the Transformer is the complex piece. There is a sample board layout in the App NOTE. I think if I lay mine out over it, the chances are it will be OK...
The stumbling block is the T
😱😱other wise U get shocked and DIE
I can always build it in stages and pieces so the sum will be great.
I have been around a while, I aint scared of the adventure the rewards are GREAT🙂
I think I will get 12 100 watt bulbs (3X4) and a variac when I can find a transformer that will carry the specs and just make it before I do ANYthing like include it on my board...
Does the output of the PFC "Have" to be 400V? Can it be 300 or 200, then do the BRIDGE components have to be voltage compatible with the output of the PFC?
well, depends on your max AC voltage you could ever put to smps, with 265Vac, that should be max voltage for 240Vac systems (If this is still true), you get pretty close to 400V anyway, and PFC voltage has to be higher then max AC voltage.
On the other hand, why not got 400v? less current, less wire, less problems. Yes you could go for only 200v, but what's the point? it's no safer then 400v, but you have less stored energy in same value of capacitor and you already ordered 450v ones, now you can use less of them for full bridge, let say one 390uF on smps, and one on PFC. since you have ordered 4, you could use 2 and 2, but as I see it, you could make 2 sets of smps+pfc
For fets, if that is what you use, irfp450 (I think), what ever I used, are rated at 500v and will have no problems with what ever voltage up to caps rated voltage of 450v
1. Well complex maybe, I don't get it right every time either, but more I do and olay with them, more I know what need to be done.The circuit itself is simple in a sense...but the Transformer is the complex piece.
😱😱other wise U get shocked and DIE...
2. How could you get shocked? I connect al the probes, and stand back, turn on via start up circuit, so that max current is limited to 1A for few seconds, so that none of the breakers go off, and by then circuit that is tested, should already work or show signs that something was wrong, before relay switches... then you can have full power
variac is always good to have, but I don't need it with this things, as I know it won't blow up coz of my mistake
I am using IGBT's rated at 600V. So that is not a problem.
I now have a good sense of this, and I am ready to more forward another step or two.
The caps should be here this week.
I think from what I have seen Coilcraft makes those transformers for PFC based on which IC you choose. I am going to call them today to see if they have one for the way I want to go. About 400 volts at 2 to 3 amps.
TIME will tell all
Now I just have to put this full bridge IGBT into a LLC transformer setup. I wish I could find a LLC full bridge example to make sure I on the right road. your insight and direction has brought what little I know in to tighter focus.
Quick question for you, now that I think about it. How can I make a seperate output on the final stage for a lower current supply, but at a slightly higher voltage?
Like plus and minus 70 with 6 or 8 amps per rail. And plus and minus 80 with only 500ma per rail. I know it will have to be a separate winding, BUT I am not clear in my own mind how to implement it. Any suggestions?
You have been a great help to me...🙂
TIME will tell all
so are you making LLC of hard switching? I still don't know if you need to go full bridge, I don't think you will need 2kw or more of power(could be wrong)
I'm not 100% what you can do, you have few options(depends, if you need it to be floating = independent of main voltage), but I think I would try adding few more turns(depending how much one turn = volts added) to each side where that + and - 70V winding ends(for non-insulated case). Those few turns will add voltage on top of that +/-70v. I don't think you need separate winding, just winding with CT, which is not centered, but more like 70v/10v
I can not get 2kw out of the wall socket anyway.
IF the ps can loaf along at 1500watts that would be great. For now I guess a 1000 or 1200 watt one would be good. I just did not want to design 2 different ones. 😀
Thanks for your patience with my ignorance of these complexities.
Thanks🙂
Thanks🙂
I think you could easy go with half bridge, less problems, less components and you have a lot of data for it
OK half bridge, with PFC and LLC, the same direction and such as CHAS1... back to his thread...
I found a great app note
http://www.onsemi.com/pub_link/Collateral/AND8179-D.PDF
Its 1KW PFC at 110 and 220
they are all about the same. My had less parts. One thing I will tell you is, look for overvoltage, I think most will have 2-5% of set one, so take that into account, so that you don't do over capacitors voltage, in your case, very unlikely
- Power Supplies
- Offline full-bridge SMPS… need help
