tube-lover said:hi bra,
U forgot to added 1.5% payapl charge, since this is a non-profit project, pls not let me lost money.
total USD158+1.5% paypal.
paypal email.
carmenh17@yahoo.com.hk
thx
thomas
Payment Sent (ID #32H16328C4053525X) for USD 160.40. Please verify.
BTW, it's bro not bra. 🙂
You're right, I sent you both an email yesterday while i was posting here ( first name equals Dominique).
I Confirm for
DAC v3 kit full assembled with CS8414 - 125 $
14 MKP matched caps - 5,50$
CD controler Kit : 25$
EMS 7$
Paypal Fees : 1.5 %
Total : 164.9 $
As soon as you will give me the top, i will send payment to
Full name and delivery Adress to
aasiu@netvigator.com
Should i wait for transform price before sending payment ?
Be waiting for your top
Dominique,
I Confirm for
EMS 7$
Paypal Fees : 1.5 %
Total : 164.9 $
Dominique,
hi,
the EI isolate power transformer include the increase posatge will USD 15.5.
will use copper foil to double shield to prevent leakage that will effect the dac.
winding in two chamber bobbin.
this is a isolate power transformers. 40VA.
pls let me know any people had interest.
pls sign up asap since it need 5~7 days arrived my hand.
I hope the dac can arrived ordered diyers before 2006-07-05.
pls paypal, & sign up your name, detail of the ower trans.
for example.
0~110 or 0~220.
50Hz or 60Hz??
sec will be same 16~0~16V
thx
thomas
for example.
0~110 or 0~220.
50Hz or 60Hz??
thx
thomas
Hi thomas,
I sign up :
One for me and one for my friend, I paypal you through a friend account
Marc
I sign up :
Marc
tube-lover said:
Hi Drew.J.K,
the cheap versio wll had TTL for CD-com, BNC, Optical & RCA input.
the special signal selection board which cobline with the USB receiver was design for the ultimate ver.3 154a & coming full parallel 1865 & 1541a, or other coming uase to save some mpney for diyers.
Pls understand this selection oard had fully use made in Japan relay, 8 pcs per board. ( USD 2.7 per one) two Nano pulse trans because the XLR input was real balance input so it must seperate
from the others input such as rca , bnc.
another questions was the US receiver was
seperate power supply , it means must use another 0~9v power rans if USB receiver use back the power supply as the PCM2706 US receiver in market. There will cause many noise by the switch mode power supply.
pls consent.
thomas
Hi Thomas
I'm trying to figure this out, analysing these curciuts with totaly unfamilier IC's is a little more than the basic EE courses i took covered, understanding the 555 was as good as it got
anyhow
So your using the CM106 as a usb reciever and a ADC via XLR's?
the signal selection board (bottom left corner of you main.PDF attachment?) the stage with mc74hc4066's and mc74hc04's, forms the backend of the USB reciever? So is the USB reciever board is only compatible with your DAC boards and not useable as a standalone unit?
The V3 cheap version kit i ordered will be OK for the USB reciever im after? its not just a board that can be used with the ultimate kit?
And is the usb reciever board factory furnished? and like the dac board comes with a rectifier/regs, so all im needing to do is hook up a 0-9V xformer to get it working 😉
and i'll take 220V 50Hz xformer
Hi Thomas
payment sent for :
EMS 7$
Paypal Fees : 1.5 %
Total : 164.9 USD
(paypal ID 4YS40991L8052960B )
Payment sent too for EI Power Transformer
EI Power Transform 15.5$
Fees 1.5 % 0.23 $
Total : 15.73 USD
(paypal ID 1HJ86260CM143671G)
I made 2 payment in case you dispatch it in two times.
If problem mail me back...
Dominique
payment sent for :
EMS 7$
Paypal Fees : 1.5 %
Total : 164.9 USD
Fees 1.5 % 0.23 $
Total : 15.73 USD
Dominique
Hi thomas,
I received your mail. So good night, i will be waiting for my payment checking tomorrow.
Do U still give the schematic ? If so could U send it to me ?
Dominique
Dominique
Thomas,
I would like 2 transformers. 110v 60hz
I will send paypal from trustek to you for $32 to cover the transformers and the paypal fee.
transaction id is 05X300407X994614K
thanks
BeerCan
thanks
BeerCan
hi beecan,
pls made sure that two power transformers was same voltage.
hi rtd, pls check the previous message whih was 4 PDF file will contain all detail.
thx
thomas
thx
thomas
rtd said:Hi Thomas
payment sent for :
EMS 7$
Paypal Fees : 1.5 %
Total : 164.9 USD
Fees 1.5 % 0.23 $
Total : 15.73 USD
Dominique
Hi, i forgot to precise for the EI -
I sign for 220v / 50 HZ
Hi Thomas,
Can you confirm that you received my payment of $159.50 towards assembled DAC ($125)+ CD rom controller ($25)+ EMS ($7)+ Paypal Fees(ID #74329883BH4775823)
thanks,
Dinesh
thanks,
Dinesh
Hi thomas,
Can you mail me your bank account with IBAN number for my friend. His bank need it or my must pay more for bank search to reach your bank account.
marc.gautsch@free.fr
Marc
Marc
hi all brothers,
Let us for the first time groups buy to build up the confidence between us first!!!!!!
This is the payapl payment received detail.
beercan-- 2 transformers. 110v 60hz
RTD-- one EI isolate power transformer
any voltage????? any Hz????
RTD again!!!-- TDA1541a v3 DAC kit full assembled with CS8414,
14 MKP matched caps, CD controler Kit , EMS.
$32.00 USD
Marc Gautsch-- 2 transformers. ????v ????hz
dine1967---1. Assembled DAC v3 Kit assembled, 2. CD ROM controller. 3. EMS.
( Hi dine1967,pls check your paypal account, since paypal message still not confirm. Very thnaks for your helpful.
Jean-Charles ---difference in payment add a CD-Controler to my order.
bro--(1) Assembled Ver 3 Dac TDA1541A with CS8414,(2) one extra CS8412-IS with adapter & gold Pins,(3) EMS shipping,(4) 14 Matching MKP Caps(5) one extra TDA1541A (matched day code with IC socket only),(6) 1.5% paypal fee.
thx
thomas
In this area I would like to say very thanks for all to support my personal production team in china although its very small ( several labour only). I was the dealer of japan tube output transformers in Hong kong. Also, I OEM some of the tube output transformers for some famous brand tube amp, pre-amp output & interstage, later I will prepare some reasonable double C-core output ransformers tube amp kits to diyers. Mainly was in reasonable price. Good price /cost ratio.
$32.00 USD
thx
thomas
Hi, thomas
I also want to order one EI isolate transformer 0-220V 50Hz 16V-0-16V.
payment sent for :
Full assembled DAC ver3 = $ 125
CS8414-CS & CS8412-IS (with adapter & gold pins) = $ 10
EMS = $ 7
total: $142 + $2.13 (1.5% paypal)
Total Amount to Pay= $144.13
(paypal-ID: 5L586300U77283544)
Payment sent for EI Power Transformer
EI Power Transform 15.5$ Fees 1.5 % 0.23 $ Total : 15.73 USD
(paypal-ID: 368307559A5212335)
thanks,
Peter
payment sent for :
EMS = $ 7
thanks,
Peter
Hi Thomas,
Thats what i wrote you
Marc
Idefixes said:Ouch I omit to indicate 0-220V 50Hz 16V-0-16V for the to trafo.
Marc
Marc
hi Stevox,
pls check from Post #308~311 to download the detail.
when will U send the payment???
hi Idefixes,
Marc, U order 2 pcs in same spec????
thx
thomas
hi Idefixes,
thx
thomas
hi,
2006-07-04 ( tuesday) Hong Kong time will be the estimate despatch day for the order DAC & parts.
Before I post the parcel, I will re-post all the items that was/were ordered by diyers in this forum to double check the order & for me to pack the parcel.
I not like to cause any misunderstanding & hope all were happy to collect this parcel.
Jumper setting of this DAC will post to forum after diyers received the DAC & can adjust the DAC in ,
1. Nos-Non-oversampling mode.
2. Nos + reclock.
3. Nos + reclock + SAA7220P/B
one DAC can enjoy three modes, enjoy it.
Every DAC I will special follow 1M Belden digital wire for U to interconnect the dac or diy your digital cable, since this is not a expensive parts, but really a useful parts.
diyers who choose EMS post method will collect the EMS s/n in the forum to personal check by themseleves in hong kong post office.
thx
thomas
2. Nos + reclock.
thx
thomas
tube-lover said:hi beecan,
thx
thomas
I haven't seen the 4 PDF attached to email you sent me.
May be you're talking post of this thread ? if not coul U send it to me
tube-lover said:hi all brothers,
$32.00 USD
thomas
So to sumup I sign for EI 220V/50Hz 16~0~16V 😉
You wrote $32 USD !!!!!! Is it amount i forgot to pay ???
tube-lover said:hi Stevox,
hi Idefixes,
thx
thomas
Yes thomas, one for me and one for my friend kit.
Marc
- Group Buys
- non-profit ver.3 TDA1541a DAC for limited budget diyers
