non-profit ver.3 TDA1541a DAC for limited budget diyers
more photos, this is funish look.
thx
thomas
Hi Thomas, thank you for the reply.
I sent you an extra $23 US for a CD-Rom controler to be added to my order. The id appears below.
ID #42J52139GS8616236
I beleive I took the price from post #272, but I realise that from post #139, the price should be $25.
A payment for $2.40 US has been sent to you to cover the difference and Paypall charges. The id for this second transaction is: ID #8WV228167Y026321C
Please confirm me, that all is correct and that my order has been changed accordinly.
Jean-Charles
hi Idefixes,
pls call your friend bank transfer to me will be Ok,
I will reserve one set to him, pls let me know U & your friend like the power trans or not, detail for the pri pls, 50Hz, or 60Hz, 110V or 220V. I will not choose PCB mount power trans becauise not easy to fix in the chassis, I will choose z11 nippon 0.3mm laminations isolate power trans 40VA to ordered diyers. This power trans was copper shield.
thx
thomas
tube-lover said:
hi Idefixes,
thx
thomas
Hi thomas,
I transmit him your bank account number. As I say it to you i will go for a 50hz Trafo for the dac. My friend To. His name is Nicolas Guenard.
Marc
tube-lover said:
hi Idefixes,
I will prepare several power tarns on my hand, let me talk to the factory can cheaper or not.
normally will need 3~4 days arrived.
will inform U later.
thx
thomas
Okay, my friend and I will go for Two 50HZ power trans. We will pay them trough paypal. My friend will go tomorrow to bank for the 162,50$ bank transfert.
This are neat trafos :
Marc
photos show was the old version dac use power trans, not the material was better. I had order for OEM japan tue output transformers already. I had source to better laminations. so, I guess the another factory that help me to OEM japan power trans will higher standard than old one. I will OEM japan double c core output trans, interstage & choke only. power trans I send to another factory to OEM for me.
don't worry, power trans U get will better quality than this one.
thx
thomas
thx
thomas
Hi Thomas that's cool. I know you will do for the best.
Marc
Great opportunities that I probably missed :bawling:.
However If not, my choice would be
DAC v3 kit full assembled with CS8414 - 125 $
14 MKP matched caps - 5,50$
CD controler Kit : 25$
EMS 7$
Paypal Fees : 1.5 %
Total : 164.9 $
I would be interested in power trans too (220V, 50Hz)
Thomas, Could you tell me if it is still possible. IF not hopefully waiting fot v4 version 🙂 and will be aware of walking through diyaudio more often.
hi rtd,
is it the same person Dominique send email to me???
don't worry, I had several spare sets on hand.
this will only offer one time, no more. pls consent.
If U lke to join this order, pls confirm asap.
about the power trans, today I will know more detail.
The first set of match MKP version, philips orange drops caps cheap ver.3 was funish & pass test already.
pls take a looooooooook, all the ordered diyers with MKP caps will collect this version.
the rectifier caps need to change already. Labours for get to change.
thx
thomas
Hi Thomas,
Could you confirm my calculation is correct? If so, I'll send you the money via paypal.
(1) Assembled Ver 3 Dac TDA1541A with CS8414 USD 125
(2) one extra CS8412-IS with adapter & gold Pins USD 10
(3) EMS shipping USD 7
(4) 14 Matching MKP Caps USD 5.5
(5) one extra TDA1541A (matched) USD 10.5
total USD 158
