No-global-loop amplification
Hi Jeff,
To answer the question about smps, the test was on a different amplifier, not the SimpelStark. I’m not changing the SimpelStark as it is a fully completed amplifier. Will most likely do this on the new version. I could send you the SMPS if you want to test them. Just need to check the voltage of them.
Do
Do you have a spare power supply to test with? Is there any info available on them? I'm curious about dimensions, ect.
The AX3 uses a separate regulated low noise supply for the input board. It will likely remain conventional.
then just have a look at the datasheet that its clearly mentioned that its output capacitance driving capability is 1pf not more than that for which they recommend using a 20ohm resistor in series on the min I would say just try with 51ohm resistors in there and see if its stable.
