Nigel Wright's Vendor Thread
Free Windows 8 PCBCAD app, just pay p+p.
I have just completed a multi app program for Windows 8 PCB design package.
If anyone would like a copy it is free and you just pay p+p
It is a basically 127 layer autorouting package.
UK p+p = £3
Rest of world p+p is £10
Email me at murtonpikesystems@talktalk.net if you would like a copy.
Software is on a DVD and requires compiling using Visual Studio 2012 RC (free trial download). There are 11 apps to compile. You just compile them once and they appear as apps in Windows 8 Metro.
For more pictures click here PCBCAD30 PCB CAD printed circuit board design software.
Send questions to murtonpikesystems@talktalk.net 07967-527693
Touch screen compatible (single touch) + slide pan (Windows 7 amd multi touch only)
2012 Windows version of PCBCAD50 PCB DESIGN SOFTWARE with 127 LAYER AUTOROUTER.
Runs on Windows XP, Windows Vista and Windows 7 and Windows8.
Fully supported product sent by first class recorded post.
Schematic and PCB symbol designer wizards.
Auto creates SIL, DIL, circular and QUAD PCB footprints from your parameters.
Schematic entry with auto convert schematic to PCB ratsnest, unconnected pin scanner and single ended net scanner.
PCB entry with 127 layer rip up and retry auto-router with clearance and continuity check.
Integrity checker, compares schematic and PCB for differences.
Component locater.
Parts list output.
Schematic/PCB component auto-renumbering and re-annotation.
RS274X Gerber file generator and NC/Excellon drill file generator.
Pick and place file generator with fiducial option.
XNA based 3D PCB viewer module.
Output schematic to printer auto-sized.
Output PCB to printer in 4:1, 2:1 and 1:1 scaling and mirroring about x and y axis.
Merge schematics and merge PCB's.
Library scanners for fast component selection.
Gerber file viewer (PCBCAD50 files only)
Component locater, block-mode for repeats, shifts, rotations etc.
Net optimizer for shortest routes.
Auto component placers for minimum routing.
Recursive auto-autoplace, rotational autoplace and swap autoplacer.
Auto-place and route recursively function for lazy PCB design.
Unconnected pin scanner.
Forward annotation function from schematic to PCB.
Screen capture to bitmap file in schematic and PCB entry.
PCB's up to 50 by 50 inches.
127 copper layers.
127 resist layers.
127 power-plane layers, each layer can be connected to a different NET.
2 silk layers (upper/lower)
Comes with symbol libraries, 4000, 7400, smd4000, smd7400 and general as standard.
User manual in each module
This is the full version and not a crippled, time limited or downsized version.
This is a fully integrated package and not a suite of amateur free programs cobbled together.
Fully supported package with email and phone help lines.
Note: This is the 2012 version and not an obsolete version.
