Nigel Wright's Vendor Thread
PCB design software details.
For more pictures click here PCBCAD30 PCB CAD printed circuit board design software.
2011 Windows version of PCBCAD40 PCB DESIGN SOFTWARE with 127 LAYER AUTOROUTER.
Runs on Windows XP with service pack 2 or better, Windows Vista (all versions), WIndows 7 and Windows Server 2003 Service Pack 1
Fully supported product sent by first class recorded post.
Schematic and PCB symbol designer wizards.
Auto creates SIL, DIL, circular and QUAD PCB footprints from your parameters.
Schematic entry with auto convert schematic to PCB ratsnest, unconnected pin scanner and single ended net scanner.
PCB entry with 127 layer rip up and retry auto-router with clearance and continuity check.
Integrity checker, compares schematic and PCB for differences.
Component locater.
Parts list output.
Schematic/PCB component auto-renumbering and re-annotation.
RS274X Gerber file generator and NC/Excellon drill file generator.
Pick and place file generator with fiducial option.
3D PCB viewer module.
Output schematic to printer auto-sized.
Output PCB to printer in 4:1, 2:1 and 1:1 scaling and mirroring about x and y axis.
Merge schematics and merge PCB's.
Library scanners for fast component selection.
Gerber file viewer (PCBCAD40 files only)
Component locater, block-mode for repeats, shifts, rotations etc.
Net optimizer for shortest routes.
Auto component placers for minimum routing.
Recursive auto-autoplace, rotational autoplace and swap autoplacer.
Auto-place and route recursively function for lazy PCB design.
Unconnected pin scanner.
Forward annotation function from schematic to PCB.
Screen capture to bitmap file in schematic and PCB entry.
PCB's up to 50 by 50 inches.
127 copper layers.
127 resist layers.
127 power-plane layers, each layer can be connected to a different NET.
2 silk layers (upper/lower)
Comes with symbol libraries, 4000, 7400, smd4000, smd7400 and general as standard.
User manual in each module
Telephone and email helplines.
This is the full version and not a crippled, time limited or downsized version.
This is a fully integrated package and not a suite of amateur free programs cobbled together.
Latest version of PCBCAD40 now here.
Latest version of PCBCAD40 now here:
pcb design software
Component locater.
Parts list output.
127 copper layers.
127 resist layers.
Note: This is the 2011 version and not an obsolete version.
More pictures at : untitled
PC controlled via USB 6 channel audio mixer with digital volume controls.
Fed up of scratchy volume controls ?
This mixer uses digital volume controls controlled by a program on your pc to control 6 channels.
Channels 1 and 2 are high gain channels for high output microphones.
Channels 3, 4, 5 and 6 are line level with some gain for ipods, cd decks and other line level equipment.
Dual outputs so one can be used for send/return.
On screen bargraph for mixer out level.
1/4 inch jack in and out.
Settings and channel names saved on pc for next use.
Comes with cd with pc mixer software, USB lead and Power adaptor.
