tinitus said:Hi
I would like some more information, email sent
http://www.ckp-railways.talktalk.net/amplifier.htm
300 watt valve front end MOSFET amplifier.
900 watt MOSFET amplifier
Valve/tube/MOSFET hybrid amplifier PCB
I have a number of PCB's for sale for a hybrid amplifier module.
Comes with instructions to turn into completed unit.
£19.99 + £2-99 p&p
£19.99 + £2-99 p&p
Re: Valve/tube/MOSFET hybrid amplifier PCB
The PCB's have now all been sold, many thanks.
nigelwright7557 said:I have a number of PCB's for sale for a hybrid amplifier module.
£19.99 + £2-99 p&p
Tube and MOSFET Amplifier modules
300 watt TUBE/MOSFET hybrid amplfier module.
600 watt TUBE/MOSFET hybrid amplfier module.
900 watt TUBE/MOSFET hybrid amplfier module.
300 watt MOSFET amplfier module.
600 watt MOSFET amplfier module.
900 watt MOSFET amplfier module.
More info at:
www.ckp-railways.talktalk.net\amplifier.htm
More info at:
Are these modules using Lateral Or Vertical Mosfets?
Your web page suggests the use of a 40 0 40 AC transformer
so 56 0 56 DC
To output 450w RMS into 4 ohms the Output needs to swing approx 120v peak to peak.
Could you quote the Rail voltages that you use on your '900W' Module? 🙂
so 56 0 56 DC
so 56 0 56 DC
The modules use vertical MOSFET's.
40 - 0 - 40 is a minimum and is playing safe. The module requires +/- 60 volts to get the maximum output. However the capacitors are 63 volt so some care needs to be taken not to go over approx 60 volts.
I have done a couple of orders for modules with 80 volt capacitors.
Or search ebay for amplifier module.
New range of amplifier modules with extras
I have just designed and built some new amplifier modules.
300/600/900 watt MOSFET modules.
300/600/900 watt 12AU7 with MOSFET output stage modules.
I can also offer a clip LED output on these amps or a 7 segment bargraph driver.
Murton-Pike Systems Amplifier Modules for pictures.
If your interested email me at murtonpikesystems@talktalk.net
Nigel
It’s just a suggestion, but could you make it with a white background and black symbols?
Cheers
Cheers
Nigel
Cheers
I tried that but I wanted different colours for different things and they looked very odd on a white backgorund.
It gives a better contrast, a bit like the Windows schemes that have high contrast black background.
Bear in mind those screenshots are jpegs and lose some of the definition.
The schematics and PCB's look much better when using the software.
Valve/tube/MOSFET hybrid on ebay
New valve tube hybrid amplifier module 300w band disco on eBay (end time 28-Feb-10 21:21:50 GMT)
Valve/MOSFET hybrid on ebay
New valve tube hybrid amplifier module 300w band disco on eBay (end time 30-Mar-10 22:24:58 BST)
Latest link as last batch sold.
127 layer PCB CAD design software with autorouter
PCBCAD40 pcb CAD printed circuit board design software on eBay (end time 28-Mar-10 16:32:20 BST)
For more pictures click here http://www.ckp-railways.talktalk.net/murtonpikesystemspcbcad40.htm
2010 Windows version of PCBCAD40 PCB DESIGN SOFTWARE with 127 LAYER AUTOROUTER.
Runs on Windows XP with service pack 2 or better, Windows Vista (all versions), WIndows 7 and Windows Server 2003 Service Pack 1
Fully supported product sent by first class recorded post.
Schematic and PCB symbol designer wizards.
Auto creates SIL, DIL, circular and QUAD PCB footprints from your parameters.
Schematic entry with auto convert schematic to PCB ratsnest, unconnected pin scanner and single ended net scanner.
PCB entry with 127 layer rip up and retry auto-router with clearance and continuity check.
Integrity checker, compares schematic and PCB for differences.
Component locater.
Parts list output.
Schematic/PCB component auto-renumbering and re-annotation.
RS274X Gerber file generator and NC/Excellon drill file generator.
Pick and place file generator with fiducial option.
3D PCB viewer module.
Output schematic to printer auto-sized.
Output PCB to printer in 4:1, 2:1 and 1:1 scaling and mirroring about x and y axis.
Merge schematics and merge PCB's.
Library scanners for fast component selection.
Gerber file viewer (PCBCAD40 files only)
Component locater, block-mode for repeats, shifts, rotations etc.
Net optimizer for shortest routes.
Auto component placers for minimum routing.
Recursive auto-autoplace, rotational autoplace and swap autoplacer.
Auto-place and route recursively function for lazy PCB design.
Unconnected pin scanner.
Forward annotation function from schematic to PCB.
Screen capture to bitmap file in schematic and PCB entry.
PCB's up to 50 by 50 inches.
127 copper layers.
127 resist layers.
127 power-plane layers, each layer can be connected to a different NET.
2 silk layers (upper/lower)
Comes with symbol libraries, 4000, 7400 and general as standard.
User manual in each module
Telephone and email helplines.
This is the full version and not a crippled, time limited or downsized version.
This is a fully integrated package and not a suite of amateur free programs cobbled together.
Note: This is the 2010 version and not an obsolete version.
Component locater.
Parts list output.
127 copper layers.
127 resist layers.
800 watt MOSFET amp on ebay
800w amplfier kit module 4 home disco band guitar PA UK on eBay (end time 18-Apr-10 22:37:05 BST)
- Vendor's Bazaar
- Nigel Wright's Vendor Thread
