NEW projector from INDIA
Re: What is the price of 10 inch lcd from Nishica model NM-1080
peterson35 said:
Hi Fibbrilator, What is the price of the 10 inch lcd from Nishica model NM-1080 lcd. Did you purchase online? I think www.nishicaindia.com does not accept orders online. How you purchased? How long it took for delivery? Please answer me. I had finished the box and done my projector with 15" Acer 1516 monitor without removing the antiglare. I've tried water soak for more than 14 hrs and the ag don't peel off. So I left it as such. After splitting the fresnel the brighness increased significantly.
So I've decided to finalise my testing and make adjustments for the panel in the mdf with my carpentor. At that time unknowingly the panels ffc got damaged inside. I see only many horizontal black lines and the monitor doesn't seem to work now.
I got terribly worried for about two days. Because my projection was about 95" width with good brightness. DVD playback was also good. But at last I've spoiled the lcd even though I had handled the lcd with due care. So I want to replace the acer monitor panel with the 10" lcd panel if it is SVGA 800x600 compliant which is more than enough for video playback/ home theatre use.
Dear Peterson,
The cost of the LCD is 5500 INR which is roughly 70 pounds.
I directly bought it from a store, not online. The display is not SVGA compliant.Also with a 10 inch screen the projected image will be smaller.
Thanks,
Gitesh
Re: Antiglare Removed
peterson35 said:
Hi Fibrilator, Had you removed the anti glare coating or using the LCD as such with ag film on? I want to know the effects of ag and removal methods in smaller panels.
Congrats for a good projector.
Hi i did not remove the anti glare .
I felt if i leave it on screen door effect will be less. Also i am not ready to take that risk for marginal improvments.
Some Questions
fibbrilator= Dear pal i would like to ask some questions.These are:
1=Why have you used such a thick heat glass?Mind it is is blocking a lot of light may be 10%.
2=Is Your reflector spherical one?If no then again you are not getting the optimum brightness dear.
I did try that screen material but i found pure bright external emulsion better than this as it is not that bright.What has your experience been like?
4=Could you please tell me the pixel size ?In 15" LCD it stands at 0.297 whereas in 17"LCDs it is 0.267.I can see some less contrast in your images.What do you say?
Dear Peterson,
You have mentioned that you got brightness improved significantly by splitting the fresnel.
How did you split the fresnel. I mean what did you do exactly. I would also like to try it if it helps improving brightness. A pic of this can be of great help.
Amit
Re: Some Questions
I dont have lexan sheet so I am doing away with 10mm float glass. 10% light block ? No way it will be less than 5% and i dont mind that as i have a 250 w bulb.
no mine is not spherical it is elliptical from a commercial projector. I know spherical will be better.Can you source one for me?
I am in a rented house so no option of painting the wall. This screen material is called flex board(used for hoardings and out door banners) as it is the material is very reflective causing glares if there are wrinkles .i made the surface matt finish by scrubbing the front surface with scrotch brite dish washing pad soaked in water.Now the results are excellent
My LCD is 10 inch.Pixel sizes are relative to panel size and the effective no of pixels in the display.Please refer to the respective data sheet for more details.
My be the images i have taken is not so great shall try again with different settings in my camera.Also my lcd is not a high resolution one.But seeing is believing. Atri sarkar had visited my place.You can ask him how it looked.
Splitting the Fresnel
I had get the fresnel separated with the help of people cutting metal, glass, plywood for swith boards. i.e switb board cutters. They have a motorised mini saw. With that they cut at the edges , i.e, left and right extremes. I'd already cut the top and bottom 1" portion out using handsaw. So the fresnel came separated.
Since I had already spoiled one 15" LCD monitor in my DIY endeavor, I'm not prepared to spoil another monitor. But after seeing the projection from the LCD, my urge to have a projector increased more. So finally I bought a DLP projector ViewSonic PJ503d which is SVGA native, interpolated XGA with D-Sub vga input, component input, S-Video input, 1500 lumens brightness, 2000:1 contrast ratio. The projection is very bright, even with 2 tube lights in the room. It costs about Rs25000.
Really, DLP is many ways better than LCD projection. Now thinking of doing my own screen, lol. I don't have camera, so no photos.
My Fresnels and Lamps are available
Following my previous reply, Since I bought new DLP projector, I am having 150W MH lamp with copper ballast of make Lewin(China Make) and the split fresnel lens, 74mm projection triplet lens from Lensel India.
Fresnels cannot be used with 15" LCD since I'd cut the edges for splitting, but can be used with LCD below 11" safely.
I had purchased the them as below
Fresnel Rs 800
74 mm Proj lens Rs960
150 W MH lamp with Ballast Rs 1500
So total 3200
I want to dispose them off as I don't need them anymore.
If any one is interested, plz let me know with the price quote.
Coparison between a DLP and our DIY
Friend why have you bought a DLP one.Were you not satisfied with the performance?
What respect do you find the DLP better than your DIY?
Which DLP have you bought and the price?
Please post some comparison shots if can manage to ?
Updated LCD!
Hello to all!!! Well guy's to start off i would like to say congrat's to all whom have finished there master piece's.This is truly a fantastic hobby my life for the past 2 yrs has drastically changed due to the DIY projector.I have tried and finally succeeded in my PJ!!.Completed some time ago and enjoying on a daily basis as soul T.V,I thought that i would take an expensive step to upgrade the LCD so this was just completed today after several day's in the conversion over the LCD is an RCA native 1024x768 7" absolutely no screen door at the projected image of 105 diagnol.Extremely happy with the image. Good Luck to ALL ! :headbash:
Lexan!
umeshkumar09 said:
Yes i have made it almost.I ran it for sometime but a friend of mine kind of scared me of UV radiation and its irreversible damage.So i am looking for GE PLASTICS LEXAN 102UV sheet.I will certainly post the pics as and when i get a nice digital camera.
Umeshlumar09 try to find some uv filtering film it's used alot and very easy to find then apply to standard sheet of glass and viola!!COMPLETE!
Dear Umesh ,
The U.V radiation story is an old wife's tale:blackcat: . First of all the light is not projected on a person and secondly the U.V that comes out of the lens will be very less to cause any problem if the light falls on some one.
Any way if you get hold of lexan inform me I will be interested in it.
By the way can you tell more about your setup? ( light source , bulb type, lcd, lens etc?)
Fib i ahve been using the following components:
Lumenlab lens kit
OSRAM HQI -T 250w W/D with OSRAM kit.
Ladle as a reflector .I got it ground by an ironsmith.
BENQ FP51G 15" monitor.
LEXAN = i am looking for.
Fib....=I found some sort of a screendor on your pics.Is it there in person?Does your LCD have a VGA input terminal?
Lumenlab lens kit
Dear Umesh.
There is a little bit of screen door.It will be visible when your are less than a meter away from the screen. But from normal viewing distance it is totally invisible.
.:smash: Also one thing I would like to point out when displaying any of the primary colors alone (red /green/blue) a screen door like effect will be visible in all single panel LCD projectors.It is because if for eg.when diplaying RED both green and blue lines will be off and dark.Causing a screen door like effect. That's why commercial projectors use 3 lcds for each color and finally combine the 3 outputs optically.
Yes my display has a VGA i/p . Supported resolution is 800 x 480.
Native resolution is less than 640 x 480(may be 320x240) could not get any documentation for my display till date 🙁
If no luck with lexan buy thick glass and coat one side with transparent plastic. Thats what I did 😀 .
Fib = you are right.I wanted a PJ for showing powerpoint presentations and movies of course.So i searched and asked a ghell lot of people and they all were at one on this that if you want an excellent quality always go for over 15" lcds as the size of the pixels is smaller.Though the size does get out of proportions but quality rules man.So i decided to go for that.As for lexan it was available @120 a sq foot but not a small piece.So i will got my friend to search for me in paharganj there are too many acrylics dealer.
Re: Oh No!!!!!!!!!!!
fibbrilator said:
OH NO!!!! :bigeyes: Dude I am afraid you pulled out the polariser film. With out it image from LCD will not be visible.
:att'n: A WARNING FOR ALL
Some lcd's do not have an anti glare film to remove. The Anti Glare surface is kind of a MATT finish liquid which is sprayed on to the Polariser film.
:dead: I am afraid it may not be possible to restore your LCD back to the original form it will not stick back again properly.Try cello taping the edges. If you use any glue between the film and the LCD it will be visible in the projected image also. :bawling:
Polariser film itself is availablefrom certain sources you may buy that and stick it on your LCD also.But could be a costly affair.
polarizer film available here
In my humble opinion it is not worth removing the Anti glare considering the risk involved and the gains are only marginal. I also feel if the Anti glare is present screen door effect is less visible.
Thanks,
Gitesh
fibbrilator,
I have a similar LCD, though I have not removed the AG yet, but I am tempted to do so, since I tried pulling the AG layer, and I know it is very dirty. So I must gain on quality if I can get rid of it, with new polarizers.
In few days I will try doing this, and may be I can seek your help if you know how to change polarizers and can extend some help 🙂
