New Markaudio MA200 8" Driver
Apologies for the newbie question but I'm looking to build my first set of speakers and the Frugel-Horns with these ma200s looks to be a good place to start. I currently have some focal chora 816(I like them but bottom end is 50hz and they need more bass) and often listen at low levels. Will MA200 Frugel-Horns be a decent listen at low levels? By low levels I mean I don't often go past 9 o'clock on the volume knob on a roksan k3 integrated.
Joan…
dave
Apologies, Joan!
Looking at the VAS for the MA200 and my very basic understanding of speakers(be kind, I'm trying to learn) it looks like the Joan is a little undersized at around 46 liters on the internal measures I guessed at from the drawings I saw? If all the measurements were increased by 10% it would equate to around 64 liters which appears a better match. Would the increased height of 3 inches cause issues with the listening angle or should I just keep the speaker at the same height as in the Joan?
I'm listening to deep-enough bass (organ, piano, bowed bass viole, plucked doublebass, bass drum etc.) in 17L TLonken, room-reinforced. The lowest notes/accompaniment are heard cleanly, not as the "lead" of the ensemble and not overly loud in an apartment with neighbors.
Reactions: Uzver
You are probably correct in this situation but never hurts to ask eh? 🙂
Though just 1/2 in in width should add up to a fair amount of volume in the Joan size Frugel-Horn and easy to adjust the plans to it.
I will do whatever is recommended of course!
Rick
