So far i have only done 1 A11ms box and none yet for the A7ms.
Contact me if you want a custom box.
dave
dave
dave
dave
Is that the CGR? IIRC it only needed a different spacer compared to the Pluvia 11.
Rectangular ,The trap version is too difficult for my tools, wonderful to imagine though. Mostly though , near field listening will make no difference to me. tks H
+1 on this. I recently finished a mini onken (trapezoid) with the 10.3s and very much prefer the mids and highs from them compared to the other enclosures with the same drivers.
Would love to build a dual driver version, this would be a floorstander I assume?
twin 11ms in a mini onken If you design it ,I want to build it. H
Those might work really well in a Nola Brio clone. Plus, very high WAF. Can't be mounted directly on a wall though.
Support them with a small powered sub, even better low reach than dual 11ms.
Need help building open baffle/bass reflex hybrid
dave
Would love to talk about a custom enclosure with you, however my multiple attempts to email you from two different addresses have gone unanswered.
I noticed that the ms7 is almost twice as light per cm2/qubic inch(of the radiating area), then the ms11
Does this make the ms7 "faster" then the ms11?
Not really. 'Speed' is inherently linked to bandwidth; if two drivers have the same HF limit, they are by definition as 'fast' as each other. However, there are other aspects involved, e.g. enclosure load and group delay, FR variations, ringing / overhang in the nominal mass-controlled region etc. (since wideband drivers use resonance to provide a large portion of their BW).
My A11ms & A7ms shipped out of WI today!
They should arrive soon enuff so tha i can have them breaking in/cooking while i am in hospital.
dave
dave
dave
Best wishes for your hospital visit Dave, I hope you can enjoy listening & playing around with the ms drivers while you recover.
...hope nothing too serious...
An aneurysm they have been watching since they did the surgery that for the burst/infected one that almost killed me. Sounds like it is fairly easy to fix, but it is very hard to get to to fix, that promotes it to major surgery. 3 hrs on the table, 10 days in hospital 2 mont setback in my rehab estimated. Same surgeons (the nurse called them the dream team) so little to worry abou there, my biggest worry is how soon will they let me move. And i hope to see some of the nurses from my long stay (most of which will need to remind me).
dave
+1Not really. 'Speed' is inherently linked to bandwidth
Sometimes stuff is counterintuitive: http://stereointegrity.com/wp-content/uploads/WooferSpeed.pdf
GM
An aneurysm........
I wondered what took you down; I've buried a couple of friends in the past two years from this, so apparently your socialized medical is better than our Medicare. 🙁
Regardless, hope all ends well, you gotta live a while longer before I can afford to make the trek to your summer blowout. 🙂
GM
- Full Range
- New Markaudio Drivers
