R5* Zero outputWith how much current bias ?
about 100...120 mA
error
this schematic contains an error during connecting zener diodes...
ltspice file
what would it take to change with a voltage of 35V and 2 or 3 pushpull of 2SK1058
may have to reduce the resistors R11 and R14 to 1,2...1.3 kohms
Negative impedance is really good for something dangerous for other things, don't ever try to drive electrostatic speaker this way, you'll smoke, as gain rises with falling impedance.
BTW this is not EC, this is a unity gain buffer with 100% feedback
THD numbers are just simulated, right? Any working prototype?
You're right, this is the result of simulation. But even if the actual numbers will be much worse anyway parameters will be high.
As for the negative impedance in the range of minus 0.1 to minus 0.3 has a positive effect on the sound.
- New Lineup IDEA - Power Follower/Output stage
