https://www.kartesian-acoustic.com/copie-de-monitoring-studio
Even better this one - what a bargain at 980€ !!
https://www.kartesian-acoustic.com/copie-de-wom120-vms-3
Are we in heaven now or in hell 🙂
Pouya, tht's the price of a Kart-Asian or 2 fridges ! How rificulous ! And you need two at least ! Better 4 fridges for your flat cooling system !
Btw - I have a accessibility problem for this thread , message says not a secure connection and then this error :
Page could not be loaded
The requested page could not be loaded.- Check your internet connection and try again.
- Certain browser extensions, such as ad blockers, may block pages unexpectedly. Disable these and try again.
- diyAudio may be temporarily unavailable. Please check back later.
Found a little info here :
https://www.kartesian-acoustic.com/copie-de-high-end
Driver name is : Sub180_vMS
Frequency range is : 30-800Hz
So limited range due to higher VC inductivity and probably a ferrite magnet , so price will be substancially lower!
I have had the same for the last two days. It made my security warning flag as not a private secure site.Btw - I have a accessibility problem for this thread , message says not a secure connection and then this error :
I have this problem only with my cell phone.Btw - I have a accessibility problem for this thread , message says not a secure connection and then this error :
With plenty of Xmax (15mm) I find it VERY relaxing to crank up the sound without having the fear to ruin the LF suspension or burning the VC !!
PLUS the enjoyment to shock others by demonstrating what LF capabilities such a long excursion 8 inch woofer has 🙂
BIG GRIN TERRITORY
Btw - we should ask The Kartesians about Passive Radiators with same basket/surround like the Dayton E150/E180 PR's were made .....
BIG GRIN TERRITORY
Expensive....but nice to see drivers like this available to the diy market.
Same here, google does not work but Safari does...I have had the same for the last two days. It made my security warning flag as not a private secure site.
So far, Google has worked for me, though load times are long, so definitely 'some-thing' going on.........
Not a TYPICAL 8 inch , that's right!
But between a 8" and a 7" - there's a universe 🙂
With a broader flange it would easily looks like one size larger .. but this quite extreme small flange makes it look like a sports car! (007 territory)
And then the gorgeous magnet!
Maybe I should offer my soul to Mr. D for this driver .. I'm feeling seduced 🙂
A 160mm and 200mm version would be also very tempting too!
I should talk to Mr. D making a visit at KAcoustics and suggesting 2 more hot options!
Let's hope for a better future ... (for all of us)
WITH 15mm of Xmax (one way) AND much more linearity over the excursion range and at the ends than most other air movers! (see Klippel graphs)
Size matters only ... until you have other options 🙂
What if you have size AND other options ? A diver like the 15" from the Klinger monitor would be cool but I guess it costs a fortune.
Charles
Charles
- New Kartesian very large xMax Woofer
