No, you are quite mistaken. "Real" does not have any variance at all. It is our reference. Sounding different in differing spaces does not diminish our conception of reality. We're fully capable of recognizing what we're hearing regardless of the room acoustics and I mean the effects of such. We don't need to hear artificially produced music in a hallway to intuitively know what that should probably sound like. We still use the real thing to qualify the artificial one.I never said anything about the "real thing" , what a "audiophool" illusion.
You could (A/B) compare a room system to a quality pair of headphones.
The real thing is someone singing next to you , tamborines and bongo's that the
kids fool around with. They even sound different in other rooms.
So "real" also has wide variance. The room and hallway is the folded
horn (or port). And street noises are the distortion mechanisms.
The real world can model the acoustic / electrical one.
OS
You didn't understand the term "hi-fi" in sound replaying electronics. It's a criteria used when judging the performance quality of such electronics, how the output is in comparison to the input, is it transparent between the two or not.Irrelevant to my point. You simply don't get it. I can't help you any further except to perhaps re-read my posts.
Your notion about resembling "the real thing" is often seen in audiophile myth threads all over the internet.
You can debunk my explanation on "hi-fi" in sound replaying electronics by showing me the method of knowing what the acoustic instruments or the singer's voice sounded like during the recording session without having been there. I'm all ears.
Source please.No, you are quite mistaken. "Real" does not have any variance at all. It is our reference. Sounding different in differing spaces does not diminish our conception of reality. We're fully capable of recognizing what we're hearing regardless of the room acoustics and I mean the effects of such. We don't need to hear artificially produced music in a hallway to intuitively know what that should probably sound like. We still use the real thing to qualify the artificial one.
You're not telling me anything I don't already know. I'm saying it means squat if it doesn't relate to what you hear naturally. It does not matter at all what the singer's voice sounded like if after it was recorded, it sounds convincingly real. No one at that point would question it except to confirm excellent performance on the part of the gear. Was it accurate??? Maybe better, an improvement! Who cares! It sounds great! Obviously it must be true to the input. But measurements of such don't necessarily reveal the truth as it enters your ears, the ultimate arbiter. So 'Hi-Fi' is always subject to scrutiny.You didn't understand the term "hi-fi" in sound replaying electronics. It's a criteria used when judging the performance quality of such electronics, how the output is in comparison to the input, is it transparent between the two or not.
I guess this is one of the reason tube amp guys have so many different tube amps.
That is what a DHT tube guru friend said to me, you need at least 2 amps for listening to different kinds of music.
As I expected, the source is your own mind. IOW, in your own mind, ""Real" does not have any variance at all. It is our reference. Sounding different in differing spaces does not diminish our conception of reality. We're fully capable of recognizing what we're hearing regardless of the room acoustics and I mean the effects of such. We don't need to hear artificially produced music in a hallway to intuitively know what that should probably sound like."Your ears
OK, fine.
In which room or setting?You're not telling me anything I don't already know. I'm saying it means squat if it doesn't relate to what you hear naturally.
I thought I was talking about recording room. Why are you keep omitting the importance of room? The only reason I can think of is that you don't understand the value of room acoustics. Let me guess, you've never seen the frequency response of the room where your audio is set up, right?It does not matter at all what the singer's voice sounded like if after it was recorded, it sounds convincingly real.
Have you ever done any recording and or mastering to use it as play back source? If not, have you ever talked to someone who's done it at pro level? If not, I'd suggest that you do. There's a lot of good info to digest.No one at that point would question it except to confirm excellent performance on the part of the gear. Was it accurate??? Maybe better, an improvement! Who cares! It sounds great! Obviously it must be true to the input. But measurements of such don't necessarily reveal the truth as it enters your ears, the ultimate arbiter. So 'Hi-Fi' is always subject to scrutiny.
But there is a chance that more faithful reproduction of the signal is the best way to recreate the sought after illusion.
This chance was explored billions of times, and where is the end result?
Faithful reproduction would be in proportion to versatility, but you can have many different audio systems, and I guess this is one of the reason tube amp guys have so many different tube amps. Who wants to collect 5 different Class-D amps. 😀
Absolutely wrong. Class D amps are just another can of worms. All of them have own flaws, and after getting first impression you start noticing them.
I finally found my amp. It is a single ended 2 stage pentode amp, with 3 nested feedbacks. It is perfect for any genre of music.
However, for 2,000 listeners in the field I use several class D amps, for efficiency. Single ended class A amps for that purpose would require own power plant and industrial-grade cooling system.
more experience of real world acoustic events enables us to more easily
fill in the gaps and make the sound more believable.
Just the opposite. The more real music you hear, the more you can (if you choose
to pay attention) notice deficiencies in the playback, which includes the recording.
You miss my point. I'm saying your SE amp with 3 nested feedback may actually produce lower acoustic distortion compared to regular "low thd amps". Designers of amplifiers measure distortion of output voltage, not the acoustic output. 🙂This chance was explored billions of times, and where is the end result?...
I like the sound of kt120 at 650V 65ma in push pull with 100 watt transformer and a special phase inverter with pentode current sinks, all caps are film, no cathode follower and only the best NOS tubes.
However, this is not quite as visceral as a good class AB with 30Amps max impulse current. like a 100 - 200 watt amps with 8 output transistors.
I think I can reach that potential using quad 80 watts transformer with low insertion loss, gaining few decibels and using lower power tubes like kt77 I think I can best the kt120 amps.
That way I can achieve tube sound with transistor sound. Best of both worlds.
You're smart enough to know where you can compromise. 🙂
Most of us can't.
I like a amp that I can not hear. Or an amp so transparent .... I don't care.
One I can drink my wine , overload it and not fry tweeters
or components.
One that is not a overweight "boat anchor". Where it needs "snakeoil"
power conditioners or silver wire to compensate for some shortcoming
that is imagined or real.
OS
or components.
OS
These are my goals -
Tube like overdriven distortion products , while intoxicated. No worry of
burnt tweeter or components.
200 watts with 4 device error correcting (class H) output stages powered by SMPS's .
.Normal listening at 20W averages , occasional HQ FLAC will track into
Class H . Best of many worlds.
No big boat-anchor amps , but still 20th century analog.
OS
For me, transparent means I don't realise the amplifier is turned on unless there's sound playing or I feel the heat radiating off of it, and Hi-Fi means better than 20-20000Hz +- 1db.
I also refuse to go past the point of diminishing returns.
Real amps do not radiate heat that you can feel. Just "snake-oil" Valve and
class A amps (with gold and silver wire) do to make you feel "magical" about something which
should be heard and not seen. 🙄
OS
OS
It is not compromise, it is optimize.
Absolutely not. Starting from a half of maximal output power distortions increase gradually, but they are not perceived as distortions, just as "too loud sound". 🙂
Below half of the max power distortions are pretty low, and the lower is the level of the signal, the lower are distortions, the lower is their order, and they decay faster than the signal level itself. It is the dynamics of the order of distortions on different levels that matter, not a THD on some pre-selected level of power.
And it is valid not only for tube amps that fool imagination. Nelson Pass's class A SS amps behave pretty similarly.
- Member Areas
- The Lounge
- New Here and think I want to hear Valve Sound
