That should be good. The way I would do it:
10000uf/R47/10000/20000uf/.1uf.
You can try simulating it on PSU designer from duncanamps.com and confirm your required output voltage by changing location of the resistor.
Thank you John65b for the advice.
I'll try this configuration : 10000uf/R47/15000/22000uf/.1uf.
BTW the config, according to BrianGT PSU PCB will be :
10000uf/15000/R47/22000uf/.1uf. (C/C/R/C)
I've simulate with PSUDII but I can only notice some differences without the required knowledge to explain the differences.
Where R47 should be placed on BrianGT PSU boards ?
There are left spaces from R3 to R12.
R1 and R2 seems to be bleeder resistors, I'll use 3K3/3W.
Nice to see you care ! 🙂
korben69 said:Thank you John65b for the advice.
As for the resistive section in the CCRC supply, I simulated this a long time ago, and IIRC was running quite a low value resistor. You actually probably don't even need to use it for the Aleph amplifier.
I don't suspect that you will get much power supply ripple with those capacitor values.
As for R1 and R2, I am using 3W 3.3k resistors there.
Brian
need files
please i need this files.
http://www.diyamps.com/aleph/docs/miniAleph-sch.pdf
http://www.diyamps.com/aleph/ps.shtml
http://www.diyamps.com/aleph/docs/ps-parts-list.xls
Re: need files
Here is the first one. I will try to find the old PS stuff from my old computer soon.
Brian
Brian
Brian
Thank you Brian !
So I just have to solder a copper strap on R3 and R12, without using any R47.
Ok, for R1 and R2, 3K3/3W resistor.
Hope it will sound soon 😎
I've got some questions too, if you don't mind.
I successfully made a dual mono LM3886 chipamp using BrianGT's boards and now want another challenge. So I ordered the amp & psu pcb's from BrianGT...
I'm gonna make a mini-A and I'm planning on using 10,000u/10,000u/R33/10,000u for the psu. I'm gonna make the R33 using three 1R wirewounds in parallel.
1. Are wirewounds OK for this or should I use metal film?
2. Are 2K2 bleeder resistors for R1 and R2 OK to use?
For rectifier diodes I wanna use four HFA08TB60's.
3. Should I go for diodes that can handle more current?
I was thinking about using a 225VA toroid.
3. Will 225VA be enough?
4. 2x12V or 2x15V?
I have difficulty in sourcing the 3 ohm resistors (R0) for the amp pcb's. A value of 3 ohm apparently is an American value. In Europe it's either 2R7 or 3R3. How critical is the value of R0?
5. Could 2R7 or 3R3 work too?
6. How 'bout creating ~3 ohm with a 5R6 and a 6R8 in parallel?
Thanks!
4. 2x12V or 2x15V?
Thanks!
Beftus said:I've got some questions too, if you don't mind.
Since a wirewound resistor is a wire wrapped around an insulator, it is also a coil, in a manner of speaking. Using one could change the behavior of the circuit.
According to BrianGT PSU BOM posted before, 2K2 works too...
Not skilled enough to give you an advised answer
4. 2x12V or 2x15V?
I'll use a 300Va/12V from Antek. 12 or 15V depends on your choice for the rail value. 12V will give about 15.5V DC
Don't know if it's a critical value or not... I'm using Panasonic 3R/3W, ref ERX-3SJ3R0 available from Digikey
Thanks!
I was thinking in creating 3k3 bleeder resistor with putting 3pcs. of 2W 10K in parallel.
Is it OK?
Is it OK?
The bleeder resistors have no effect on the sound. All it does is discharge the caps when the amp is turned off. There is no magic about its value. Anything over 2k2 is fine.
A single 10K is ok. The higher the resistor, the longer it will take to discharge the caps.
Someone correct me if I am mistaken.
Of course it does not affect the sound, but as I understand the dissipation here is a matter to consider. For that reason it is not recommended to use 2W 3k3 here, but 3k3-3W or 2k2-2W. Correct me if I'm wrong.
Since I have a source for 2W metalfilm resistors (but no 2k2) I thought it is the simplest for me to parallel 3 of those 2W 10K for this job. I just wanted to check if I got the math for paralleling right. Resistor Wattage is added when paralleled, isn't it? So I figured I get about 3k3-6W with this configuration.
korben69 said:
Thanks for sharing your thoughts Korben69.
I'm aware Digikey can supply me with the 3 ohm resistors, thing is I have the majority of parts already ordered @ www.hifituning24.de. Just ordering the resistors @ Digikey is likely gonna cost me a fortune in shipping compared to the price of the resistors. Digikey isn't an option for me, I'm on a budget and have a wife you now! 😀
Beftus, try this ref on eBay 270301976166, less expensive... reliable and fast delivery.
If you're still in trouble send me a PM.
Thanks for this Schuro link 😉
PSU board
Isn't It better after bridge to have C - R - 2R instead of 2C - R - C
regarding Inrush current
On the PS boards and in reference to the PS pdf posted a short while ago:
I dont see reference to C1 and C2. What values are they?
R3-R12 are said to be replaced with a short. ? Why? What situation would warrant using resistors here? What value would they be?
R0 has two different values in the BOM. 4.75k and 10k. Which is correct?
Thanks Guys/Gals
Uriah
Thanks Guys/Gals
Uriah
I imagine C1 and C2 are snubbers and would be .1uf. I will go with that.
Reading back through and still unsure about R3-R12 as well as R0.
I am noticing that people are using 22kuF, 15kuF, 22kuF and other combos.
Whats the deal with the different capacitances? BOM states 10 or 22 kuF depending on using mini or 30 style Aleph. I would do mini monos. 12V toroid. Was going to purchase a bunch of 10kuF Nichicon KG caps. Any reason to not just use 10kuF on each cap?
Uriah
Uriah
Yup, they are snubbers. 0.1uF will do fine. I think that's what Brian suggested in the BOM.udailey said:I imagine C1 and C2 are snubbers and would be .1uf. I will go with that.
As a matter of you want one big C or CRC. CRC will have a bigger voltage drop but lower ripple.
From what I have seen, the resultant value of 0.1R seemed to be the most commonly used for the R which can be a bunch of 0.47 in parallel or one BIG 0.1R. The only thing to look at is to make sure the resistor's rating is adequate.
[/B]
Uriah [/B][/QUOTE]
I have 71K uF per rail for my mini and can remove the 35,000uF very easily. Quite frankly, to my not so sensitive ears, I don't notice any different with only 36,000uF per rail.
Fred
Thank you for your reply and for turning me on to this build.
So maybe I will go for a 15V toroid and use the R47 resistors. I imagine 3W will be fine on each resistor. Will check Digikey for those great Panasonic resistors.
Oh, Any idea about R0? Is that just for the LED? Probably wont matter the resistance if thats the case.
Uriah
Uriah
- More Vendors...
- Chipamp
- new batch of mini Aleph amplifier and PSU boards
