New Amplifier - ULD Extreme
Terry,
The board mounts parallel to the heatsink by way of 4 screws at each corner of the PCB making for a very space efficient solution. The output devices are sandwiched between the heatsink and the PCB. The leads of the output devices will have to be bent at 90 degrees to accomplish this. This is different from the version that appeared in the magazine article.
Carl_Huff said:
Terry,
Works for me. Thanks Carl
Terry
HI Carl,
First, apologies for late reply. It's Sunday afternoon and I've just completed the board check.
I have found one problem only. I believe that the lag comp cap, 100pF, is terminated on the left side at the BASE of Q8, not the EMITTER of Q8 as you have it on the layout.
I have thought about D1/D21. The series orientation will protect the 220uF MUSE cap to -1.3V reverse polarisation if the output goes negative wrt ground. If it goes positive, then with 55V rail, the feedback node may rise to 0.51/12.51 * 55 (+2.2V) which is still within the 16V rating. If you connect the diodes anode/kathod and kathod/anode across the cap, then neither DC polarity from rail sticking can ever exceed 0.6V across the fb cap, which will permit using a 6.3VW cap, much smaller. This won't affect amp operation, however, and is merely a nicety. Back to back diodes will not affect AC operation, BTW.
Otherwise, it's a very nice layout and I doffs me hat..... thank you for contributing it.
Hugh
Carl et al,
You guys have been busy finalizing this amp. Do you think we are ready to implement all of the schematic changes into a pcb build? This will be my first project using the Thermal Traks. How do you see the bias on this amp. Run the outputs hot or let them have an easy life.
With six diodes in the multiplier circuit do you expect to need an adjustable pot here?
Tad
Tad,
Now that I have included Hugh's find the PCB layout is complete. You have room to experiment with the tempco diode string. The pot is there to 'fine tune'. There is quite a lot written about that earlier in this thread and in the "Silicon Chip 200Watt LD amplifier" thread.
I just got back a quote from my favorite Chinese PCB maker. The cost for a double sided board, 2 oz copper, silkscreen and solder mask amounts to ...
100 pieces $6.00 each, 80 pieces $8.00 each, 60 pieces $10.00 each plus 'ship to' fees.
Is there sufficient interest here to do a group buy?
Carl_Huff said:
Tad,
Hi Carl, I will take 20! That should start things off!
Can your supplier send out two packets, one for the USA and one for AUS. I volunteer to resend the Ausy ones out to individuals as required.
Terry
