New Aleph Mini PCB GB
Transformer options
All,
I don't want to steer this thread off course, but I would appreciate to hear your opinions on the following.
Which makes the most sense for an Aleph 5 implementation
1. Dual 2 x 25 400VA
2. Single 2 x 25 1000VA
Neither may be optimum but I have them in hand.
Thanks for your thoughts.
Ryan
hi People
stuffing my pcb today. Im going for aleph 5 , it seems I will have to swap c2 for r12..... but looks quite straight forward... not much else different. I am trying to take notes of the parts difference so I should be able to post the alternative parts list and stuffing diferences afterwards.
regards
dave
transformer spec / using one power supply board
I also have a question regarding sizing of transfomer for a STEREO Aleph 30 using ONE of Brian's Power Supply board.
Is this correct for minimum requirement?
Dual sec coil, 18-0-18, 650VA (1 piece) or
Single sec coil, 18-0-18, 320VA (2 piece)
Retired diyAudio Moderator
Joined 2002
dhole said:
Brian
I think I may have found an error on the boards. C1 (or c11 on aleph 30 or c5 on aleph 5) has the polarity marked on the board wrongly. the + leg should connect to R9.
Can you confirm this .
regards
dave
You are correct. Thank you for pointing out this error. I will put an update on the website. Here is a comparison of the schematic and the manual. I am sorry for the mistake. I will send out a mass e-mail about this soon.
The prototype amp (same amp board layout) has C1 with the polarity backwards and worked without problems:
http://www.briangt.com/gallery/miniALEPH-prototype/Brian_GT_Mini_Aleph_044_copy
I will talk to Mark and see if he noticed any problems. Sorry about this issue.
One more issue that I found last night, if you are using the 4 pin caps on the power supply board, you will want to remove the 2 unused pins, as the connected to the + capacitor lead, and this might cause problems. I will include this in a mass mail, and I will put an update on the webpage.
Brian
Joined 2002
dhole said:
Hey Brian whats the led resistor value on the psu board ? I can work it out but it dosent seem to be on the parts list, so might be worth updating for others.
regards
dave
Dave,
I have updated the parts list on the webpage:
http://www.diyamps.com/aleph/ps.shtml
The correct designation for the resistor for the LED is R20, which is a little hard to read on the pcb. It is the rectangular component closest to the LED, and the right resistor choice would be a 4.75k 0.5w resistor. I choose the compact metal film ones available from Digikey:
PPC4.75KXCT-ND
I am sorry for the confusion. I had forgotten to update the parts list to match the finalized power supply board layout.
Let me know if there is still some confusion.
Brian
Brian,
I've looked at the schematics. For minimum requirement, is this the right spec for the transformer for a stereo Aleph 30?
330VA, 18v-0-18v secondary, 120v primary (Full load amp on secondary side = __)
If I'm utilizing the resistors on the PS board for a CRC configuration, would there be some sort of voltage drop across the resistors? And thus should I order the transformer with a little higher voltage on the secondary side? Say 20v-0-20v?
Joined 2002
dhole said:
Cheers Brian
I had kinda guessed it was r5 , thanks. Still other people will benefit from the updated parts list. Thanks alot for the boards again .Oh do you have a spare psu board ? only bought 3.....
dave
I have about 10 power supply boards left, and 20 amp boards left (not including some boards I set aside for people who haven't paid yet). I will leave them available on the order page until I am completely sold out.
http://www.diyamps.com/aleph/orders.shtml
Best of luck with your project. I am hoping to get mine done soon, but other things keep on popping up, keeping me busy. I am going to try to put more time into this project this weekend.
Brian
Joined 2002
fcel said:
Brian,
Without the CRC, 18-0-18 would be the minimum for the Aleph30. My initial plan was to try one of these per channel:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=122-620
due to their quick availability.
If you are going to experiment with the CRC, 20-0-20, 500va might be a good choice to try out for a stereo amp. Victoria Magnetics should be able to wind a custom transformer for this if you are unable to find another source.
Brian
