New AK4497SVQ Build!
Based on my experience with the noise from previous builds, I decided to add an isolator and move the MCLK to the DAC side.
The si8661 I already purchased seems to fit well with the USB-I2S bridge (i2s, mclk sel, mclk/2 for MCU).
Feel free to recommend an isolator for i2c that would work well with this!
I'm also considering using a CPLD on the DAC side behind the isolator to align the i2s edges.
It would be easier to integrate since I'll need other glue logic as well.
I also need to use a high-performance clock buffer to achieve the purpose of the CCHD clock.
I have several xc2c64a-7vqg44 and epm240t100c3n.
74LVC1G80 is cheaper,
I think about 74LVC125 or similar, for what you need trigger here? To make re-clock?
It is not necessary for AK449x.
but CPLD have been playing comfortably for several months at my room
It's fine if you use the CPLD for other purposes too, but using a CPLD instead of a simple buffer like the 74LCV125 would be a big overkill.
Moreover, the buffer is not needed there at all, you can connect the signal from 8661 to the DAC.
Of course, through series resistors of 30-50 ohms, which are required in any case, also before/after the buffer too, to dump ringing.
Alex.
OK, in this case CPLD maybe useful (I said: "It's fine if you use the CPLD for other purposes too").
P.S. However, I use or simple logic (75LVC157 for USB-SPDIF I2S switching), or DIX9211 as SPDIF receiver and also I2S switch (and other functions), "to put all of this together".
Alex.
Reactions: Mins
This thread is for discussion and advice from DAC developers.
Hopefully you are aware we don't always all agree with each other on some things.
For your first dac design of this scope you are getting one set of mostly agreeable opinions. That's okay, but there can be more information and opinion to be exposed to over time.
