Is it possible to upload pictures directly here (jpg) or do I have to go through URL link? My new slot loaded bass system is now up and running and I would like to share some viewpoints.
Please do Sluket, this I have been awaiting! 🙂
Use URL-link.
just get it over with, or i wont be able to sleep tonight.
the suspense is killing me! 😀
What do you prefer?
Front firing with slot or like Nelson has his?
It's a good question. Actually I don't have a chance to compare them in a clear enough way. So don't take this too seriously.
For a pure sub, I think the original NP style slot is better. With at least 2 drivers, it got better sensitivity and overall output within a relatively compact package. And if you go push-pull, there's an additional benefit -- cancellation of even-order distortions.
If you use this up to lower midrange, the simpler front firing driver with slot maybe better by it's less pronounced resonances which are also pushed higher in frequency. Because the dimensions and volume of the cavity is smaller.
Your SUSPENDERS are killing you..?😀
I'd better give you a little teaser, then....
Have no URL-links, so here goes:
VERY NICE!
10 x 12" (?) per side?
We want pictures, impressions, data, measurements, your evaluation of OB vs. slot-loaded etc; the whole story 🙂🙂
10 x 12" is for sissies - these are 15". No less.
I'll see what I can do maybe next week...... right now I am too busy just playing MUSIC through these "flat to 17 Hz" 108 dB/1m. 300 kg./side 7' tall
"compact" woofers...
Georgeous!
Thanks - and yes, they DO look good; I always thought that design, execution and finish should be top notch for any serious projects - has something to do with commitment and pride of ownership. Important issues to me.
This should give you an idea about proportions... the handles are SS316 with serrated grip, sleeves in DZ brass with M16 threads (basically similar to 5/8"). The discs are also inSS316 and about 75 mm. (3") in dia.
Bloody nice
😀 I was kinda hopin' for "FUCKIN' HELL!!" or something in that neighborhood... but bloody nice will do, thank you! Much obliged.
Anyone in mood for some more pics?
- Nelson Pass: The Slot Loaded Open Baffle Project
