need help to build my own smps based on blaupunkt schematics gta400 please
i use le lcl filter and the noise disappear 😕
the waveform on gate is
the waveform on drain is
i put rectifier diode and i have +27.5v and -27.9V without condensators on each rail.
without rectifiers the voltage on transformer is really important 108V at powerup
I remove the clc filter and i put rail capacitor
It's strange the voltage go to 2x29.8 volts and grow up slowly to 2x30.1 ...2x30.2 etc i stop at 2x30.6 i dont know what is the problem ???
i also replace all resistor already use by new because old serve to test the smps
I have this to gate
to drain
Is it normal ?
