Need Advise - Radford Crossover Inductors
You will note that the image you have copied & are pointing too is copyrighted. You should link to the original:
Your link has been removed.
dave :cop:
OK, it's a little high, and that is your compromise. To be honest, it will work well enough if you have no options.
How is the sensitivity of the drivers? The heat dissipated by inductors is mainly related to their resistance, and less copper handles it less well. Ironically iron cored inductors can (typically for a given price, for example) have a lower resistance but also suffer at higher levels due to the core saturating and the inductance dropping. It's an apples to oranges comparison. If the air cores can manage your power levels they will be fine once you maybe adjust for the slight effect of the resistance on the driver levels, possibly by increasing resistance to the others.
We are talking about old KEF drivers here so not exactly high power.
I have a pair of KEF Concerto's that have the same drivers T27 B110 & B139
The original power rating was 30 watts (altough I have them on a 150 watt per channel amp!)
I checked the crossovers and found some of the electrolytics were completely out of spec. Caps were replaced where necessary and most of the small values changed to plastic caps.
As regards the large bass inductor I found that a replacement high power ferrite core inductor from Falcon Accoustics was a worthwhile upgrade and gave a far better bass definition than the standard KEF crossover inductor.
Audio Inductors 4.01mH - 6.00mH, ferrite, air core, iron dust.
The original DN12 crossover used in the Concerto's was the weak link. This Radford updated FN12 with all aircore inductors will make them shine.
I will be hand making these Radford xovers for my dads Bailey's.
I'll take a shot at it. I see Erse has got all the inductor measures online, for Dayton I'm not sure I see any. Would you measure Length and diameter for I would draw these as 2 dimensional objects on a board in a pcb making software so you can solder all the conections on the bottom side of it and the upper side would be clear from it, with -IN+ ; -W+; -M+ ; and -Tw+ only. I think I'll need a day or two for it.
