Nec Lcd1545v
Takusma, check ebay for an LCD monitor. Shipping will be a bit more, but its better than paying those prices you are talking about. Also, I hardly think you care about the warranty on one of these 🙂
If it doesn't work out, then put it back together and sell it again.
Someone's idea about the internal construction being different? Just because the internal construction is different doesn't mean that you can't take it apart, you will just have to take it apart in a different way 🙂
I think (speculating) most LCD's will come apart contrary to peoples beliefs. I just took apart an old Dell 386 laptop for the LCD screen the other day, it came apart fine. They were using a sharp LCD in there.
About the screen, be careful cause no garuntee that you can take it apart.
Also, I didn't find a brand name on it which is all that much worse. Try to find the manufacturer that makes the actual LCD
Thank you for the information Psionic. 🙂
I just emailed Goldenshop asking for the name of the company and if they had a site, and I am of course eager (sp?) to get their reply. :nod:
Let's just hope that it will be a good reply.... :scratch:
here it is but the specs still need to be validated like you said
MONL9-150TV
²£«~¤ÀÃþ ¡G LCD MONITOR
²£«~¦WºÙ ¡G Topcon 15" LCD
²£«~«~µP ¡G TOPCON
²£«~´y_z ¡G 15" LCD TV monitor
Contrast Ratio: 700:1
Brightness : 350 cd/m
Resolution : 1024x768
Built-in speakers
DVI, VGA / Component input
PAL I / PAL D/K / SECAM (TV/Monitor)
+ NTSC (Monitor) Mutli-Color Systems TV Tuner
Picture in Picture, Video Zoom
S-Video In, Video-in, Sound Output,
Multi sound-in
Digital Frame Memory of screen
With Remote control
it seems that all topcon's monitors are high contrast lowest one i have seen is 400:1 and 700:1 as the highest now if i can only find the responce times (cause i know 5ms is bull) im guessing its 5ms rise and 11ms fall for a 16ms lcd but who knows im interested in this one and im gonna do some searching to weed the specs out
nice find takusama:nod:
Thanks cruser but it's you that we should be thanking, you found the name of the company and also managed to find some specs too!! :nod: :nod:
Ps. :bigeyes: 😱 :bigeyes: @ "Component input"!?!? Jesus!!
"Ring Effect"
Hey guys,
I noticed people complaining about the "ring or halo effect". This is a problem with the fresnel itself. Most of the fresnels sold dont list "Grooves per Inch". The more "grooves per inch" the better the fresnel. 400 GPI is the highest I could find so far. With this... you have no ring effect no matter how close or far you mount the lcd from the it.
