My ZD-50 ultralow distortion chipamp.
jackinnj said:
Try examining this amplifier with a 10kHz square wave. What's the slew rate at full power?
Slew rate is limited by LM3886, and typically >15V/uS. Here is 20kHz square wave test.
Thank you. Actually LTSpice already contains the LT1363 model, and I used it.
juma said:
Great work Nikolai ! :up:
Thanks!
Can you tell more about listening tests?
I will hardly be able to do the justice to the amp in few sentences.
We have had extensive listening sessions where we compared the amp with Creek 4330MK2 and
Creek 5350SE hooked up to Revel M22 monitors and Audio Physic Spark loudspeakers.
The most noticable difference is in the bass, which is tighter and better controlled.
and in the soundstage, which is more solid and precise but, suprisingly, less expansive.
The high are grain free. Overall, the amp is very dynamic and musical.
I'd like to second this.
And thanks for sharing the link to the Yewen composite amp article (which I haven't seen before), which really is essential understanding your amp (at first I couldn't quite disassemble all those multiple feeback paths, now it has become clear, a very clever design idea).
- Klaus
I've made this amp on my own 2-layes PCB a couple weeks ago. Here are THD and IMD measurements. The right channel on the graph is the amp input, the left is the amp output.
So, what about the sound? Very transparent and clean, with good bass performance. Transfer of a vocal is very natural. I’ve compared this amp with my previous favorite amp http://astral-for.narod.ru/index/stones/amgen.gif. ZD-50 is just better at any type of music. My other components are 3-way homemade speakers (magnesium Seas Excel drivers) and AD1862 based DAC.
Actually, I think if 50W is enough for you, it will be very hard to find a better amplifier.
Here are some pictures
http://fotoplenka.ru/users/antecom/422197/
jackinnj said:
Mbe I'm missing something here -- here's a phase-gain plot of the input stage --
Personally I do not see anything wrong with this frequency response (-3dB at 75kHz). If you think you need a more flat response, just reduce the values of C2 and C3, or do not install the input filter (then the input is R7).
I already posted the amp frequency and phase response vs C3 graph http://www.diyaudio.com/forums/showthread.php?postid=1577734#post1577734
x-pro said:
You need a fast opamp in an LPF if you want it to work properly up to fairly high frequencies (i.e. CD-player output can contain some components in MHz range) . AD8065 used probably because it has very low THD.
Cheers
Alex
Hi Alex and welcome to my thread 🙂 !
Yes, because the AD8065 has a very low THD, even at very high frequencies. So I see no difference in the perfomance with or without it, except the SNR. Also the AD8065 has a very low input offset voltage.
Actually the U2 can be AD8065, LM318. The U1 I think can be ADA4898-1, but I did not test it yet...
Mykola,
Thank you very much for this excellent design!!! I have built a simplified version – one of 6 blocks that I need for my 3-way system. I could not believe my measurement results! Even with LM318 THD were lower than I can reliably measure with Juli@ (20W, 8 Ohm, 10kHz), that is below 0.0003%.
I also tested operation of the amplifier in Current Source mode. It works great!
I am not sure how to implement a power supply for 6 channels properly. Any ideas?
lumumba_p said:
Mykola,
Of course the THD% is lower, the amplifier is bandpass limited.
