My ZD-50 ultralow distortion chipamp.
I have most of the parts to stuff the boards. And four boards. Nick gave me the boards. If someone will build these I will give you a real deal on the surface mount components.
My surface mount skills are poor. I doubt I would ended up with two working channels if I stuffed all four.
Nick was extremely generous in sending four boards. Wish I had built them.
I just looked at the site. It is not a current source output, but does have some detail LS like Mauro Penasa’s My_Ref.
The plots look good, but cannot read the text.
If anyone wants to build I have four boards and a bag of parts. The amount and sizes of surface mount parts stopped the stuffing of the boards. I know my poor SM soldering skills would eat me up.
Ultralow distortion LM3886 chipamp
Hi everyone! It is my first message on this forum and I hope it will be interesting for you.
So, my power amp is based on LM3886. It has a very deep feedback - about 70dB at 20kHz, and much more on lower freq. It considerably reduces distortions compare to the standard schematic. I started this project almost one year ago, and now I have a very good working one. It has about -120dB THD at 11kHz, 4Ohms, 60W. IMD 19+20 is less, and I could not measure it.
Here is the schematic, parts list, PCB layout.
Some measurements.
That's it for today, I hope I'll post more soon.
Nick.
Hey nick Im interested in documentation but... unfortunatly.. the s-audio site admin has blocked the new member registration. Can you attatch here? Thanks
Reactions: Zoji6645
Has someone built this amp?
I put it on LTSPICE, and it seems to be not correct. Please see Mr. Evil post of the original schematics.
In the first picture, X2 in- gets feedback from its own output and from the output of the main OP. But in the 2nd picture, in- of LT1363 only gets only the feedback from LM3886, but not from its own output.
The simulation of my final version RD-50.
After I simplified it, I found out there was a same version published in 2019.
in the sim, I used AD711 instead of LM3886, because it looks like LN3886 on the spec.
I also used LT1028 in the place of LM3886 because of its open gain phase curve in sim matches LM3886 on the paper nicely.
it is very interesting to see phase shifting when U3 is fast or slow. R10 can also have affect on THD.
