My version of an Ultrasonic Record Cleaner
Here's the deal on deionized water. It does want to absorb ions from wherever it can. It readily does this from the air (CO2 and dust). Unless you're running a URC that is a closed system not exposed to the atmosphere, you will not have any problems in a stainless tank.
Even if the DI water absorbs ions from the steel instead of the air, it takes very, very, very little ionization to reach equilibrium. Equilibrium happens in minutes, rather than hours. The water will still be more than clean enough for record cleaning, at less than 1ppm of TDS, and your open air stainless tank will be unharmed.
Numerous studies support the use of stainless steel (particularly 316 stainless) for piping and tanks holding DI water, even for months at a time. Note the high compatibility ratings of stainless in these references:
Graco Chem Guide for DI
NASA Research
Where DI water can cause problems in stainless steel systems is where there are stainless steel welds that aren't done the proper way. This is why some people think DI water cannot be contained in stainless --- because the welding issue was misinterpreted to be a general stainless steel issue. Unless your tank has welds exposed to the DI water, there will not be issues.
Your goal is to get clean water for your bath. Whether it's DI, or distilled, or purified; any of these options will work and given the intermittent service conditions, you won't have any problems in this application. I suggest one uses whichever is most economical in your area.
B B
Thanks BB
I have a tank from Louis but I have no idea about welds perhaps he can confirm?
Got this today for £3.50 just waiting on my Tergikleen from USA
The tanks we use are 18:8 stainless steel (also known as 304 stainless steel). It appears, after research, that the amount of ions pulled from stainless steel is negligible.
I did find that using De-ionized water is reported to be suitable in Ultrasonic Cleaners, as it not only increases cavitation, but also helps remove contaminates.
Here is a link to this information:
Difference Between RO and DI Water for Parts Cleaning, Washing, and Rinsing
-Louis
Thanks both for all the help.
I still haven't even turned the US cleaner on yet since I bought it back in nov/dec !
Once this tergikleen arrives I will begin a test and looking forward to getting into the world of clean records.
Try it with just water first, then compare with TergiKleen cleaning and subsequent rinse. It's good to understand what different components/chemicals do for you.
Hello and thanx to all who have contributed to this DIY US cleaner thread. I am new here and have been trying to plow through this entire thread, however my eyes are nearly falling out and I'm only about 1/6th of the way through!! I am trying to find the recipes for the various cleaning solution concoctions that have delivered acceptable results, but so far have only found the proportions for the distilled water/IPA/photo-flo one. (Perhaps they are tabulated somewhere further along in this thread?) I am looking for quantitative information as my US unit is a 45 kHz, heated, with a 3 1/4 gallon tank. I am particularly interested in the info on the Alconox recipe as I have some on hand.
Also, as I have a small (about 5 gallons/day?) electric water distillation unit, I have access to as much as I can make, but I would prefer to minimize the volume of solution needed per tank fill which leads to another question that may have already been covered somewhere in this 180-some page thread......does anyone know of a way to decrease the tank capacity of my 3.25 gal. without affecting it's cleaning efficiency?
leoniru
Hi Leoniru,
I don't use Alconox, but the manufacturer recommendation for this detergent is 10 grams per liter of water. I think you'll find that is way too much for ultrasonic cleaning.
If I were you, I'd start with about 1/10 that amount and see how things work. This type of detergent will require extensive rinsing. That is one reason I am a fan of isopropyl alcohol instead -- less rinsing is required to remove it, and what's left will evaporate. The salts in alconox will remain on the surface unless rinsed. These salts aren't really a danger to PVC, but you'd want to rinse them off.
As to the size of your tank, there isn't a great way to reduce volume without hurting efficiency. It presumably has more transducers than the typical 6 or 10 liter tanks most are using, so, depending on tank dimensions and power, maybe you can clean more records per cycle to up your efficiency.
B B
Thanx bbftx for the info. As I don't want to get bogged down with extended rinsing requirements, I'll likely be skipping the Alconox route.
As I have more money than time at the moment, I cheated a bit by purchasing one of the Vinyl Stack setups. I will be adding filtration at some point as well. Will be finishing off after the US cycle with a Loricraft vacuum unit that I picked up several years ago but have yet to use as I've only recently been able to dig out my system after 15 years of storage.
Was hoping that someone somewhere along in this thread had tabulated the various 'soup' recipes that have shown promise for US cleaning and their merits and disadvantages. I've tried the search function but it doesn't seem to save me any time from reading through this thread page by page. Guess I'll plow through as I have time to do so.
Wasn't it a conclusion in this thread that the ultrasonic frequency needed to be 60kHz or higher for best cleaning of LPs? This unit, though it has a number of useful features and ready-to-go operation, is lower in frequency than the common 40kHz Chinese units on eBay.
Rotation is too fast to allow effective cavitation cleaning. Had a 36 KHZ unit it was worthless for cleaning records. Kind of a snake oil sales pitch, cleaning the record "applying" the snake oil anti fungal cleaner.
Design is ok and Decent price point. Too bad they didn't use 60 KHZ and 1/10th RPM motor.
I agree with Zg's comments and would add the Kirmuss ad copy is particularly troubling. Trying to look scientific, they claim on their website: "In an ultrasonic cleaning machine, explosions occur millions of times per second, removing contaminants."
This is absolutely NOT what happens. The cleaning mechanism is Implosions, not Explosions, and there is an enormous difference between the two.
Also, this doesn't occur "millions of times per second," it happens about 35,000 times per second in their machine if you believe that spec.
Elsewhere on their site, they talk about the cleaner coming with "blotting paper" to dry the records after they emerge from the machine. Blotting paper, seriously?
They also claim higher frequencies damage the tank and records to justify their choice of a cheap 35k underlying ultrasonic machine. Absolutely not true and not supported by any evidence.
B B
B B
I agree with you! And from myself I'll add that it's just marketing that tries to justify the applied power of 35 kHz and so on! We all have been experimenting for a long time and came to the conclusion that 40 kHz and above are very suitable for our tasks. In addition to the quality and speed of cleaning, the speed of rotation of the engine, the capacity and the thickness of the walls of the bath, as well as the power of the ultrasonic generator unit affect the cleaning.
P/s
I came to the conclusion that if you use the power of the ultrasonic unit of the generator 180w and the operating frequency of the generator of 40 kHz for faster cleaning, a slower speed of the engine 1 rpm is needed in this case the vinyl is longer in continuous cavitation mode and is accordingly cleaned during the same period of operation better.
