My Transistors, original or copy?
About a year ago I posted here that the MJL1302/MJL3281 had changed appearance with the replacement of the A-version with the AG-version. In addition I posted a little further (#506) that the datecoding system had changed from YYWW to YWW with a letter indicating the year > 2010)
As of 2014, the datecoding system was changed back to the YYWW system. OnSemi's smaller transistors stick to the YWW datecoding system where a single letter indicates the year.
I never posted a picture of the TO-220 range (e.g. MJE15030/15031), but around the same time the bigger brothers changed appearance, so did these smaller types.
In addition to my previous post, I took some photographs of a MJL3281A "old style" and "new style". I just noticed that the new version is type A again, rather than AG. Last year I thought I found that the A was going obsolete.
The change happened at the end of 2012. From then on we've used hundreds of these and never saw the old style again.
Also some pics of an MJE15030 old style and new style. The datecode seems to indicate a change in 2010 as the most recent batch carries E47, presumably meaning week 47 of 2014. If so, counting backwards must mean that A = 2010.
Again, after the change the old style was never seen again, so if you're dealing with these that have a datcode of > 2010, but look like the one on the left, I'd say it's a fake.
The change in how they look must be the result of moving the production location. In both cases the first two letters were changed. From some research on OnSemi's LM337 (because of a problematic batch), the first letter indicates the plant at which they were assembled. E.g. on the LM337, lot trace codes starting with "R" mean they were assembled at a plant in Roznov, Czech Republic.
Just in case you wonder: all these transistors were bought from authorised distributors like Avnet of Arrow and are 99.9999999% certain to be genuine.
Small corrections to above post:
Datecodes starting with A = 2011, not 2010. The change from old to new style with the TO-220 was somewhere during 2011. For the TO-264 it was during 2012.
Newest datecodes on the current work in progress could therefore never have been starting with E (they're actually C, i.e. 2013).
FYI, not saying they are fakes not to be sued by the seller, I've had problems with some components from ASWO pro seller. (Was once a decent seller.)
"Technics" STK8050, been through 3, output shorts instantly.
"Infineon" ICE3B2065J, they sell one more expensive one for "Samsung" no problems with that, the cheaper version (5263163) I've had one OK, one with not original-looking encapsulation and nothing semiconductor inside!
"CT" CT2N5551, had 4 pieces old stock from around 2006, used them all to replace the 2N3859A (Crown "2961", Q105, Q108, Q205, Q208) in an Amcron DC300A amp, one channel wouldn't bias, it turned out one of the 2N5551's was a PNP....
Wondering about this MH15003G
Popped one open. It measured 2.83nF
Die looks suspiciously small, and the silicon goo all over... hmm
Insights? Didn't even know people made fake transistors, that's like putting a lot of work into faking working at work or something...
Its not about making fakes but relabeling no name ones. TO3 package is very simple to clean and put whatever you want in letters on there😉
I've just purchased some 2N3055s.
The die size looks OK as does the heat spreader.
Anyone recognise the maker ?
Andy
Do people also be carefull when open these transtistors? it can contain Beryllium oxide, and is is very dangerous.
Most is afcourse found in HF transistors but a warning is on his place here, special when fakes.
