My Take on X-BOSOZ
Here is the simple controller PCB. The controller usues 5 pins for driving the relays via the transistors, and one to read an ADC pin which sets volume.
Russ, you are spoil'in us😉 I would definately be interested🙂
any word on a remote or a display.
A remote would be nice indeed, the display also😉 The only thing missing then is a remote controlled input selector, with built-in function for shorting the -IN to GND when selecting one of the SE inputs😉
The X-CC-CCS-BosoZ is pretty silent. Normally you place the volume control at the output (when speaking of the BosoZ) because any circuit noise is attenuated when turning down the volume. I didnt try to wire it in front of the circuit though. Maybe its doable? Did anyone else try that approach?
Steen😎
Steen😎
Wow i had a whole thread on this. The location of the pot.. In front of the pre or after the pre.. Humm.
i think it should be tested.. Right now im running this..
cd player > dac > buffer > Volume pot > mini a's ( using the dac )
If gone this way..
cd player ( rca out's ) > Volume pot > mini a's this works too.
Eek, sorry about that. Fixing now....
So as for the output caps. It appears I have enough of the Jantzens for all current kit orders (that is, orders that have been paid for). I will ship all pending kits out on Monday with the Jantzens. If I somehow missed a kit in my count (not actually home right now), I will fill those orders with Solen 20uF caps from PE.
Now, the problem is that more Jantzens will be 30-60 days out, and I can't get many Solens from PE (they can get me 40, but after that it's a few here and there). Not very impressed with their wholesale side of things, I must say. They can supply as many Dayton caps as I can order, and Russ says they are very good.
I can't immeadiately find another good supplier of Jantzen or Solen in the same price range (easy to find Solens for a lot more money). So, I am thinking of using the Daytons in future kits. I found Steeno's Rifas at Elna, but when you add shipping and 25% VAT, they are not such a great deal anymore. Unless I bump up the cost of the kits, which I hesitate to do...
Thoughts?
Okay, so I just found a spectacular source for the Solen 20uF caps.
Thats a great choice😉
I am looking forward to see Russ's work on the attenuator🙂 Sure enough he will come up with some great stuff😀
I agree with moe29 that it deserves its own thread, but please point to it from this thread!
Steen🙂
