Hi
I think you don't need it that high, I have 33 ohme I think, you can check that...100 would be still fine, but if you don't have any problems leave it as it is.
now i put 33ohm instead of 380ohm rd and then effeciency rised from%65 to %75 and the frequency rised to 70khz from 60khz
Hi
Which core do you use? I use 50k which should be enough for 800w+, so I don't think you will need 70k, but it all depends on type of core that you use
Hi
Uff ETD59, lower freq. At 20K you still would get 1kw. And skin effect will be much smaller.
See here
http://sziget.mine.nu/~danko/letoltes/Magnetics_design_application_notes.pdf
See here
Hi
Ok, but still skin effect is present... So how does it work, do you get 800W out of it? And why do you need such power with only +/-42?
Hi
That is not that much power, won't you use something bigger?
Try using even lower freq., say 30k, I would be happy with that...
is that possible to convert this project to adjustable power supply. for example 0-100V 10A power supply?
is that true?
if i change the zener diode (connected between output voltage+ and 4N25), i can set up the output voltage. Than if i replace the zener diode by adjustuble zener diode , i can control the output voltage. Thus this project cab be converted the adjustable output voltage smps.
but in here. do i have to change ETD59 transformer?
- Power Supplies
- my smps project help
