My MOSFET amplifier designed for music
Goldie99 has kindly pointed out an error in the quoted values and part numbers for C2 and C3 in the Speaker Protection circuit of post #1796
C2 & C3 being shown as 47uf / 63V. The BOM 'value' shown is 47uF, but the Mouser part number is for a 4.7uF / 63V, albeit obsolete already.s
The value should be 4.7uf, 63V and the Mouser part number I actually used when building my one is 710-860020772008
Put a test report of the RMAA
Reactions: decramer and Mooly
Got some time today and tested both the channels using a smps.
Readings channel 1 and 2
Supply : +/-39.5vdc (home voltage is usually high at my place)
Opamp pin4: -11.95vdc and -11.91vdc
Opamp pin6: -4.86vdc and -4.85vdc
R19/20 junction: 1mV and 1mV
Across R5: 0.556vdc and 0.567vdc
Reactions: Mooly
@Mooly Forgive my ignorance here Karl, I'm about to place Mouser order this weekend for Geoff's boards, Will substituting R26 0.22R output resistor for 0.15R be very detrimental? I suppose the speakers only 'see' the last resistor.
I have a pair of unused Mills MRA 5W 0.15R non inductive resistors in the stash. For R23/24 I already have these in 0.22R. (thought they were Mills too)
The power dissipation should be equal in each FET as they are simply in series as far as current flow is concerned (assuming no load attached and no signal present). The current in R23 and R24 should be equal
Or is it due to the 0.1 resistor with the positive supply?
There are no resistors in either supply rail. This is the original artwork from many many years ago and these are the only low value resistors in the amp.
Reactions: manniraj
Powered up first amp board and I used a 0.1R/5w resistor in series with the positive supply and I set the bias to 0.01v. Input is shorted and offset is 0.00mV
Made the inductor using 16awg and 14 turns and put it off board and will be connected when all finished.
A better way of powering an amp for a test is to use a lamp bulb in series with one of the AC power line wire. The bulb is a good detector in case of faults it will also detect if the amp will self oscillate.
Cheers!
  • Thank You
Reactions: gannaji
More to the point - have you got the 10ohm 2W resistor in parallel with the inductor (it's there to damp the inductor impedance)?
Yes it’s on the amp board itself 10R/2W resistor
Yes I know I always do it on my amp builds but as I am using a smps didn’t use it.
Reactions: de Ocampo
Yes it’s on the amp board itself 10R/2W resistor.
If I'm not mistaken the resistor on the amp board is NOT in parallel with the off-board inductor. According to the circuit diagram and Prasi's layout, this is R26 and is shown as 0.22R 5W. See Mooly'post#1, the relevant part quoted below:
1. The circuit diagram in this, post #1 is correct. The only omission is a 10 ohm 2 watt carbon/metal film across the output coil.
Reactions: manniraj
