bullittstang, have you gotten around fixing the issue? After reading about your issue, I am interested in assembling mooly's amp using recycle parts that I collected over the years. Actually, I started out restoring/modifying an old amp. But my collections of parts are limited. And was looking into using mosfets. I have more of vertical FETs than literal. Which brought me here. I am trying to see how I can easily change BJTs to FETs or Darlingtons.
bullittstang - because you mentioned there are noises when probing binding gnd post, I think you have a bad power supply. Test with another power supply. The power supply core wires might be touching each other internally or the chassis. Or test the ps by removing the amps, and see if its pulling current.
Late response - I put the amp boards away and have been building two other Nelson Pass Class A amps that have been sitting around for a few years. I removed and tested all actives as well as every resistor and diode and everything checked out both with DMM and Chinese parts tester.bullittstang, have you gotten around fixing the issue? After reading about your issue, I am interested in assembling mooly's amp using recycle parts that I collected over the years. Actually, I started out restoring/modifying an old amp. But my collections of parts are limited. And was looking into using mosfets. I have more of vertical FETs than literal. Which brought me here. I am trying to see how I can easily change BJTs to FETs or Darlingtons.
You could be right on the PSU, but it was from a working amplifier I recycled and I have the same issue with a different Toroidal/Capacitor bank outside the chassis on my test bench, so I am at a loss at the issue, so it will sit until I have some time (and desire) to get back to the fixing the problem.
I recently had some PCB's made at JLCPCB, as per Prasi's design & Gerbers (Post #904 - https://www.diyaudio.com/community/...esigned-for-music.119151/page-46#post-5870255), and have some 'spare' boards available. They were made in 1.6mm FR-4, Blue, with White silks, 100% as per Prasi's Gerbers, and I have 6 PCB's available @ £1.10 ea. Anyone interested who'd like a set, please just drop me a pm.
Alan
Alan
Alan
Hi Goldie99 🙂
You have mail.
Best regards
rephil
Hi Alan,I recently had some PCB's made at JLCPCB, as per Prasi's design & Gerbers (Post #904 - https://www.diyaudio.com/community/...esigned-for-music.119151/page-46#post-5870255), and have some 'spare' boards available. They were made in 1.6mm FR-4, Blue, with White silks, 100% as per Prasi's Gerbers, and I have 6 PCB's available @ £1.10 ea. Anyone interested who'd like a set, please just drop me a pm.
Alan
Thanks for your offer, I think I sent pm but the system is changed from the last time I used it.
Let me know if it has arrived.
Aubrey
Hi Goldie99
Two PCBs from you cost here the equivalent of 2,2£ = 2.64€. The belgian post says your pack did arrive in Belgium today. They want me to pay taxes at 19,19€ for the delivery home, this means in pounds : 15,99£. Sorry Goldie99, but I can't understand this way of proceeding : I think at once to thieves. The post writes that these PCBs will be sent to you in april 06 if I don't pay them before this day. As they obliged me to use only their system of payment, no other one, I will not pay the 19,19€. Please feel free to provide these PCBs in another good home when you get them back.
Best regards
rephil
Best regards
rephil
Hi Rephil - I'm sorry to hear that - makes no sense to me at all, except some kind of 'Brexit' issue. The customs forms were correctly completed, with the correct value declared (£2 20), etc. - please do NOT pay anything at all. I will refund your previous payment this morning, and get them to you, free of charge, by another means.
In the mean time, I'll contact Parcelforce and try to find out what & where the problem is ? Will pm any additional info I get.
Best regards,
Alan
Best regards,
Alan
Hi Goldie99
Don't worry for the money my friend, please, don't give me what I did pay for the PCBs : I would only be pleased if you provide these PCBs to a good home, maybe free if so you want. My friend, the Brexit is a real pain for all of us ! So don't add other pain to what these "nice" people already did to you and to me ! If you want to get the copy of the paper I have recieved today from the belgian post, only say it.
Have a nice day Goldie99
Best regards
Best regards
Hi rephil,
i can offer you 2 pcb from the same version (designed by Prasi). The only difference is black pcb with white silkscreen. the price is €4 plus shipment. shipment to you should be quite cheaper since there is not tax inside EU
Günni
Günni
@ Goldie99
Thank you for your refund, but it was not necessary. Maybe in other european countries will you find only taxes to be paid, and not the 15€ a pop that the belgian post takes for their intervention.
As you see, I think positive ... Have a nice end of this day my friend.
Best regards Alan
@ schillg11
I am interested in your offer, and as I buy many things in Germany (e.g. Reichelt), I know that the delivery is fast and not so expensive. You have pm.
Thank you for your so inexpected and friendly offer.
Best regards Günni
Best regards Alan
@ schillg11
Best regards Günni
I suggest to move R23,R24 and R43,R44 in the source of output mosfets. As they are now, there is no Vgs balance between mosfets.
Tibi
Tibi
Hi question how many watts can provide not reaching clipping max power @8 ohms load and 4 ohms loadAnd here are the pictures of the amplifier PCB assembled and tested 🙂
The enclosure is finished, I will publish pictures soon...
Marc
Tibi, plse give us a schematic of your idea.I suggest to move R23,R24 and R43,R44 in the source of output mosfets. As they are now, there is no Vgs balance between mosfets.
Tibi
Just move R23,R24 and R43,R44 from drain to source. As they are now, one mosfet will run hotter than other.
Or you need to match them perfectly to have same Vgs at chosed bias. Anyhow, these resistors should be not placed in output mosfet drain.
Tibi
Tibi
- My MOSFET amplifier designed for music
