Joined 2002
For those who think they have a problem with downloading the files (i thought so too at first) here is the schematics anyway (hope it's ok gmarsh)
http://www.ettnet.se/~tobias/diy/sch.png
Joined 2002
So am I correct in my guess that each input is in a different format, and you simply switch what format it is decoding?
since people seem to be having trouble with rapidshare, i've split up the file and i'm posting it in this thread.
This file contains the main Eagle .brd/.sch files, the AVR microcontroller code and the front panel designs.
You'll need Eagle Hobby or better to edit the files; the schematic has two pages and the board is 160x100mm 4-layer. To compile the AVR software, you'll need avr-gcc - Google for "winavr" if you're using a Windows machine. And the front panels are designed using the software from http://frontpanelexpress.com
Hi
Nice project ! How many MHz is the crystal? Will it accept 44.1khz and 48Khz input? This project seems to be perfect for my digital room correction PC... only need to replace the I/V stage.
Best regards
Kim Olesen
Best regards
Kim Olesen
The crystal is 29.4912MHz. I'm using the 'CB3LV' series from CTS Corp, available from Digikey.KimBOlesen said:Hi
Best regards
Kim Olesen
Acceptable input range is 32 to 192KHz.
Hi Folks,
If Gmarsh doesn't mind, I have a lead on where we can get quantity discount PCB's and do a group buy for this project for fair price (actual $ depends on interest level, hence quantity).
Cheers!
Cheers!
Joined 2002
Geek said:Hi Folks,
Cheers!
Id be interested. 😀
Gmarsh,
Very, very neat stuff. I haven't seen too many folks do their 4 layer boards on here.. If you haven't already, you should post this on head-fi -- those guys'll spaz out over this 😀
Go ahead, hack up the design, do a group buy or whatever.Geek said:Hi Folks,
Cheers!
But as said before, give credit where it's due and don't make a ton of money off the design without buying me a beer.
Posted it a while back... http://www6.head-fi.org/forums/showthread.php?t=124371motherone said:Gmarsh,
If spazzing means criticizing op-amp selection and the choice of the TPA chip, then sure... I avoid that forum like the plague, since the majority of the DIY discussion is about how different pots, RCA connectors and wire sound. My engineer's mind can't handle that. 😀
Does this mean I can't tempt you into spending some time in the Digital Drive of the Audioasylum ?
rfbrw said:Does this mean I can't tempt you into spending some time in the Digital Drive of the Audioasylum ?
Sounds scary, but I'll bite sometime.
I was afraid of diyhifi at first but it's a good place. 😀
You have to visit, if only for the comedy to be had from the various gurus dispensing their wisdom.
Willl the micro code attached cycle through all the mux inputs on the cs8416, or just the two? I would like to add more inputs.
Many thanks
Hans
Many thanks
Hans
mbcouple said:Willl the micro code attached cycle through all the mux inputs on the cs8416, or just the two? I would like to add more inputs.
Many thanks
Hans
No, just through two. Making it scan through several should be a simple code change.
- Digital Line Level
- My latest project - DAC + headphone amp
