My First Tube Preamp
R17 and 12a/b I remember tweaking a little bit to dial in my B+ where I wanted it.
I seem to remember using the 100 ohm on R17 and somewhere around 2K (4K paralleled) for 12a/b
My advice is start middle of the road and take measurements with the tubes in...
So....That being said, a higher R17 will reduce the B+ since it is in a series circuit with R12a/b?
It looks like there is a capacitor tied in there between R17 & R12a/b, is that some sort of a voltage divider circuit?
Does that capacitor have anything to do with the B+ level?
Should I start with one of the middle values that were supplied (200Ω or so) instead of the 470Ω that I used since it fell between the 10 & 1k values?
Its really just a CRCRC filtering of the B+ Capacitors will have an effect on the B+ but the standard values are just fine.
Really as long as you land somewhere between 250 and 300 or so that is the key. The voltage with the tubes out will be much higher since there will be no current flowing. Once the tubes are in and all running at ~10mA you can calculate what the drop will be calculating the values of R17 and R12a/b. V=I*R
Slow But Steady
Here is the raw chassis after I burned the pattern onto it before the finish is applied.
The volume pot will be on the left side centered, the power switch will be on the right side centered.
Hopefully this weekend I will have some time to build the last few spacers for the power supply support.
Then I can install the power button, IEC socket & volume control.
Once that is finished I can put the roundovers on the corners and oil the chassis.
I'm really hoping to begin testing this weekend.
Chassis Finished, Final Assembly Begins
I have finally completed assembly.
After a bunch of holes, 4 coats of Tru-Oil & 2 coats of gun stock wax......Here She Is!
This was truly a time consuming yet very rewarding process.
Who would think a few pieces of hardwood flooring would look so good with such a simple finishing process.
Power Wiring Help
I am in need of help, I think I have the heater power figured out but my power transformer has a single 220v output no CT.
Does my HV wiring look good?
I have the 220v tap to the B+ pad with the ground of the 220v tap to the CT pad.
Is this correct?
Here is my transformer, Antek - AS-05T240.
B+ Pages
Here is a scan of the B+ pages in my assembly manual.
After further reading I think the grey and yellow should go to the two AC pads inside the circle.
This is the input of the Full Wave Bridge Rectifier.
Are my understandings correct.
I/O Wiring
Here is some pictures from the underside of the Preamp.
I have chosen to use RG316 for my I/O wiring, it's nice and small with silver plated copper conductor & shield.
It is very nice to work with and its Teflon dielectric & jacket make it suitable for high temp use.
Crackle
OK....I have plugged it in with heater power only I hear a very faint crackling sound.
I unplugged the unit and started feeling for hot capacitors....did not find any that were warm even.
I then checked for polarity and found all capacitors were proper polarity.
Where should I look next?
Should I plug it back in and test the heater voltage to make sure the regulator is working?
OK I think I have the crackle taken care of.
I removed the CT for the heater because at closer inspection I discovered that I have configured heater for FWB w/o CT.
After I removed the CT I tested again and heard no crackling.
The Heater +- measures 6.28VDC, Perfect for my 6CG7's.
Now I'm on to testing the heater with tubes installed to make sure there is no large voltage drop when the regulator is loaded.
