But you’re using it from 300Hz upwards, so what use is the Q for? That’s a bit above the resonant range…Thanks, so I should look for 0.5, as transient response is what I aim for with a mid woofer.
Ow I missed that. Well, -10dB at 40Hz can’t be your target highpass goal, or is it? A moderate 6” design does a far better job.Thank you markbakk, what makes you think they are not very good? I’d like to learn what to look for as this fr doesn’t look awful to me?
Thanks.
