My Decware Zen "Clone"
Yellow sheet mod. With HV Schottky and little 2R2 resistors (Thought they were 68R) feeding them from the hv taps.
I really like the idea of an all-film cap power supply using Vishay or Wima DC-link caps. Maybe when I eventually do a nice SE amp I'll try it out. Something like this build is a good place to go for it.
Here are a few photos of an all film cap build I did of the SE84CS. I also put in a switch to choose between Russian Teflon and Mundorf Silver and Oil coupling caps.
Here’s the link to the build…
https://www.diyaudio.com/community/threads/documented-single-ended-triode-el84-build.351338/
^ Nice.
I've used Solen in the past, but prefer to use non-audio marketed parts generally, as they generally present better value for the same or better specifications. I've been looking at stuff like these. It would be easy to make up some simple brackets to mount them out of aluminum flat bar stock-
https://www.mouser.com/ProductDetail/Vishay-Roederstein/MKP1848C61050JK2?qs=zDkSFN9STR99T7i7l5iS8w==
https://www.mouser.com/ProductDetai...KP1848C62050JP2?qs=HVbQlW5zcXVP42Oqof%2BXyw==
https://www.digikey.com/en/products/detail/kemet/C4ATGBW5200A3MJ/2783190
https://www.digikey.com/en/products/detail/kemet/C4ATGBW5100A3FJ/3078819
^ Nice.
https://www.mouser.com/ProductDetail/Vishay-Roederstein/MKP1848C62050JP2?qs=HVbQlW5zcXVP42Oqof%2BXyw==
As I am in Canada, the Solen caps from Solen Canada were a reasonable choice at the time of the build, which was a while back. I’m not sure if that is still the case. I recently purchased a bunch of DC Link caps for a 300B build, after reading good reports. https://content.kemet.com/datasheets/KEM_F3125_C4AQ_M.pdf
You'd need to run the power stage cathode at high voltage, or run a negative rail to do that really, then things get a bit tricky and it totally changes the design.
Running a decent cap there is a way more elegant solution in my opinion. Something like the Jantzen or an MKP will be pretty blameless there.
