Sir,
Thank you for you suggestion...expect for shematic and pcb with power supply, or provide me the link where I will get all details of AUD600
Pravin
Pravin
AUD600 with sub crossover
Use my AUD600 with sub crossover
Thank You for your suggestion...Please share a link for details of AUD600 with sub crossover.
Pravin
Pravin
Hi Manoj,
What is the differences between EE type cores (ER-ETD-EE,etc) and toroid cores in class-d application ? because i think when we replace toroid cores with ee types , zobel network resistor becomes more warm..is it true ? can we reduce output HF with suitable filter ?
Hi IR,
not all toroid cores , only iron powder core with low AL value is good for class d(b'cause they have enough air gap) or toroid ferite core with 1.2mm gap is suitable for 500W RMS class d amp.
MANOJ
Hi pravpa,
Hadi will give you the link or you can search this forum "ucd-25-watts-1200-watts-using-2-mosfets"
MANOJ
Thanks Manoj ,
but i used ER42 with 1mm gap and it was so good , better than T130-52. how much gap is good for ee type cores ?
Thanks sir manoj for your good class D amp
Hi sir manoj🙂
you was started your AUD600 from page 266 and this is link
http://www.diyaudio.com/forums/class-d/166214-ucd-25-watts-1200-watts-using-2-mosfets-266.html
have nice time diyers
Hi pravpa,
MANOJ
Hi sir manoj🙂
Hi IR,
it depends supply voltage applied to the amp / max. 4mm gap and min. 1mm gap
MANOJ
Hi Max,
These are my old class d designs don't ask me the schematics(again go for searching my scratch papers)all parts are listed in the silks screen layout except post 22(1000W amp)that i will give you on PM if you are interested.
MANOJ
Please send my mail: as.rebachuck@gmail.com
Hi ravpreet,
OUT R resistor 1K connected wrongly(connect to Vcc pin 8) cut the print line and connect to out 2 pin 7 use a small wire😉😉
MANOJ
MANOJ
Manoj Sir,
I have gone through the forum and downloaded the necessary artwork for AUD600. I would like to know the total expenditure to make a budget (in Rs).
Pravin
Hi Prav,
MANOJ
Manoj Sir,
Pravin
Hi Manoj,
what is the effect of gate resistor on mosfet dissipating power and fsw of amp ?
39 ohm gate resistor is good for 250~300KHz and IRFB4227 ?
Hi Pravpa, do you mind posting the artworks for AUD600,I have gone through the forum and downloaded the necessary artwork for AUD600
Im also going to make this Amp, but finding all the details isnt made easy.
Hi IR,
gate resistor is very critical on high frequency side. MOSFET gate capacitor increases the resistor value decreases and gate current will increases
practically i found that freq.=300Khz=130nC = @1A and i don't know the calculation
another i found above 25 ohms gate resistor will give the stability (max.100R)
MANOJ
Thanks Manoj
please refer to this post :
http://www.diyaudio.com/forums/class-d/182900-class-d-amp-lm566-lm393-2xirf530-27.html#post3337303
- Class D
- My class D amp
