My class D amp
Hi Manoj:
For last few months I was experimenting on your aud600 ver1. Today mistakenly I gave .1uf cap and instantly 2k/2w resistor blown away. Replaced that and removed .1uf with 1uf cap.
But there is no audio even no grid. Replaced all ICs but no response. All relative voltage is okay, relay connects, no overload nothing unusual. Still no response.
How and what I can check? I don have oscilloscope. Please suggest.
Raj
As far as oscilloscopes go, the Rigol DS2000 series gives the most bang for the buck, but if you do not have 800 dollars to spend and absolutely cannot wait until you do, the next best option is the Rigol DS1052 for just a mere 400 dollars.
Hi Manoj:
Raj
Hello sir. Can u shere ur experiments with us ..?
Thank u
Hi Raj,
1. Remove 1nF capacitor connected to GND near 1N4148 x2(pin-2 of IC TL071) and use 33uH coil and add 1K resistor paralell with 1K 1% (frq. adjust)
2. Connect 1KHz signal if you have or any audio signal with min. volume
3. Check Pin-5 of IR2110 with DSO with respect to GND(it will show @400KHz square signal)
MANOJ
Hi Raj,
MANOJ
Thanks Manoj, I will try to manage a DSO.
Can i short with jumper if I don have 33uH?
Raj
