My best discrete preamp with 3 transistors
Distortion is caused by the non-linear relationship between voltage and current. Your three-transistor circuit is doing well because the current remains nearly constant. The op-amp version can do well with two more transistors for current-source biasing.
Ed
Thanks for your tip.
But the idea of this thread is 3 transistors.
With higher number of transistors it is possible to get even lower THD. I am almost sure.
I want to see 3 transistor circuits.
Here is an improved version of the original circuit.
Uses a BC337-40 output transistor.
Now output is at 6.00V and this gives a max output 5.8Vpeak at THD 0.1%.
The THD at 1Vrms out is now slightly higher 0.00011%.
