My alpine amp makes a high pitch squeaking sound
Perry Babin said:
Add a 2S prefix to the numbers.
2SA1265N
2SC3182N
An ebay seller has both.
I don't know if the N suffix is important. 2SA1265 and 2SC3182 are likely the same exact part. The following are from MCM.
http://www.mcmelectronics.com/product/MCM-TOSHIBA-2SC3182N-/2SC3182
http://www.mcmelectronics.com/product/2SA1265
And with those old obsolete parts, I wouldn't trust E-bay any further than I could throw it. Chances of getting a phony are very very very high. I would use the Fairchild FJA4310/4210 (140V) or the FJA4313/4213 (230V) from Digi-key.
when i take the transistors from the good channel and put then in the bad channel that sound comes back then when i put them back in the other channel it works again so there must be something else wrong with the bad channel could it be some of the transistors on the power supply side of the board
Upon closer inspection of your picture, that amplifier has a chip that drives the transistors. As far as I remember, they very rarely failed. I really don't recommend pulling the driver chips until you determine that there is a problem with said chip. Did you check the 4 3 legged resistors? Maybe Perry will have some help for you.
/\ I don't think one or more of those emitter resistors being open would cause any oscillation, those are regular PnP and NpN output transistors, right?
So it has two seperate IC's, one to drive each channel's output transistors? Those are the two with the aluminum sinks, correct? Unless its something before the IC's, maybe between there and the rca jacks, I would suspect the driver IC in the cranky channel's circuit. Just looks like too simple of a circuit for anything else. But you never know what the amp's been through in its long life, lol.
year i brought this off a guy that i brought a broken amp off before but managed to fix it just had some cracked solder joints when i got the alpine amp the right rca input had a cracked joint so the right channel has only been used recently so the left channel has had a lot moar use then the right one might have something to do with why it died
as far as i know they are
If the driver transistor reads anything near 0 ohms across any of its terminals out of the board, it's defective. You can pull the one from the good channel to try it in the defective channel. Check all of the outputs that you use in the defective channel before installing them to confirm that none are shorted.
Are the driver ICs UPC1298s?
