my 3886IGC pcb
I am building the amp with the PCB's of Digi01 and can't find the capacitor (Cin) from 4,7 mu with a distance of the legs from 5 mm of 10 mm. All what i can find is far too big.
Does anyone know were to get is???
Thanks a lot.
Hi Wim
If you look at Zangs picture his cap is raised. I don't know if the board was designed to have the cap sit on the PCB.
I just rx'ed a new set of boards from Zang and they have pads for surface mount components.... I may go that route..
digi01 said:
Hi kzar and all,
the 3886igc boards are not available now.I am planing to make a updated version.
any recommand input are welcomed.
Zang
none that i can see ... still tring to figure out why mine arent working... i might buy some new lm3886s to see if the ones i got by chance were bad...everthing else on the boards are correctly installed checked them over 3 time before soldering and 3more times afterwards... only thing left is the IC.
Steve @ Apex . jr sells them cheap. Where are you in TX? Email direct with answer.. stgrab@yahoo.com
I have some of these boards still unassembled, and we can build / photograph each step and component used.
cedar park...10mins outside of Austin.. well im using pretty much all dales for resistor and miss ordered some parts and had to reorder... let me find my invoices and ill post what i used...
im leaving in a few hrs so i wont be able to get to it ...
I have a few of the first boards, very nice indeed. The only suggestion I would make would be to move the chip a little further toward the edge of the board. I found that I had to grind off the edge of the board in order to mount it flush to a heatsink.
/Dave ... still a loooong way from that 6 ch amp I decided to build in 2004.
