JLTi
your gear looks really nice. You might find this interesting to look at, its a sight in Australia i found the other day....
http://members.ozemail.com.au/~joeras/index.html
Really nice looking amp
I am building the amp with the PCB's of Digi01 and can't find the capacitor (Cin) from 4,7 mu with a distance of the legs from 5 mm of 10 mm. All what i can find is far too big.
Does anyone know were to get is???
Thanks a lot.
Thanks a lot.
You are right Rabstg, it is mounted above the board. By the way, it looks like a bipolair capacitor (Black Gate).
Thanks anyway for your reply.
Hi I was wondering if there are any of these pcbs kicking about as I was thinking of making a stereo amp?
Hi kzar and all,
the 3886igc boards are not available now.I am planing to make a updated version.
any recommand input are welcomed.
Zang
Zang
digi01 said:Hi kzar and all,
Zang
none that i can see ... still tring to figure out why mine arent working... i might buy some new lm3886s to see if the ones i got by chance were bad...everthing else on the boards are correctly installed checked them over 3 time before soldering and 3more times afterwards... only thing left is the IC.
Hmm what circuit would be a good one to make then? I liked the sound of the gain clones because they are supposed to be easy to make but sound good. I would like somthing better than my mission cyrus one basicly. Thanks
Steve @ Apex . jr sells them cheap. Where are you in TX? Email direct with answer.. stgrab@yahoo.com
I have some of these boards still unassembled, and we can build / photograph each step and component used.
cedar park...10mins outside of Austin.. well im using pretty much all dales for resistor and miss ordered some parts and had to reorder... let me find my invoices and ill post what i used...
im leaving in a few hrs so i wont be able to get to it ...
wont be able too i work retail this was one of the rare times i had the whole weekend off.. but here soon i will get pics taken...
wim said:I am building the amp with the PCB's of Digi01 and can't find the capacitor (Cin) from 4,7 mu with a distance of the legs from 5 mm of 10 mm. All what i can find is far too big.
Thanks a lot.
I have realized this issue.I will make enough room for the ver#2 3886igc.
You will probably not find it. Normally 1 uF/63V is the limit for small caps.wim said:I am building the amp with the PCB's of Digi01 and can't find the capacitor (Cin) from 4,7 mu with a distance of the legs from 5 mm of 10 mm. All what i can find is far too big.
Why is there an input and output coupling cap in this amp?
Also if my buffer has a 1uf cap on the output can I skip the input cap?
Where is the output coupling cap? Hardly in digi01's pcb?Nordic said:Why is there an input and output coupling cap in this amp?
digi01 said:the 3886igc boards are not available now.I am planing to make a updated version.
I have a few of the first boards, very nice indeed. The only suggestion I would make would be to move the chip a little further toward the edge of the board. I found that I had to grind off the edge of the board in order to mount it flush to a heatsink.
/Dave ... still a loooong way from that 6 ch amp I decided to build in 2004.
Nordic said:What is the DC tab for?
its a node for work together with mine preamp.
- Chip Amps
- my 3886IGC pcb
