why is that? such comment usually adresses some very low impedance dips, but this seems not to be the case here?Originally Posted by Lojzek
This new Satori mid dome impedance does not look like a healthy one.
The impedance graph shows not a single resonance bump (of the dynamic system) like one would normally see, like in
satori-tw29d-b/ but a hat shaped response below 1 kHz which looks like it's actually from two resonances at about 350 and 600 Hz, the latter corresponding with a dip in the output. So, there is some kind of resonance going on at around 600 Hz. Does that matter? Dunno. You have to cross over above that anyway.
I wonder if it is two resonances, or simple one but with the center peak quite effectively damped by some feature? Afterall the overall impedance magnitude is quite low for an Fs.
Don't think so, but since we don't yet know the details of the construction we may only guess. The product isn't out yet, this may as well improve for the production model.
If I were to make the datasheets, I'd put a thick PRELIMINARY across everything that isn't fixed yet so that copies of unverified info don't get into circulation on the internets without a warning, at least.
Transmission line resonances? Normally there are two humps. Guessing the chamber has same issue.
We are aiming for November. There are no plans to offer a stock waveguide for this driver.
Ulrik??
I thought there may be some announcements about the waveguide tweeter, textrene and 2” done mid at IHEAC last week, nothing has hit the forums yet?
I asked my local retailer (in germany) and I can preorder the SB Acoustics MD60N-6
for 14,4€ per piece.
The delivery date is not available yet...
I gather you mean 144€ each ,please keep us informed if you decide to go ahead and purchase .Any further testing available for the MD60N ? I really hope the Munich speakers could be released as a kit with a pre made cabinet option .A friend heard them and was very impressed so the hype is real
I preordered two for 28,8€. I was surprised too. Maybe it's a mistake...
I'll write here if there's anything new.
Wow ! Santa is being nice for you
Any more news on your delivery date and whether the price was correct. Now marked as open for pre-order on the SB website.
The store came back to me and said they made an error - the price will be 190€ per piece (in Germany).
They are making up for it with a 20% discount.
But still there is not date for availability.
Thanks for the update.
Hmmmmm......
At that price it is significantly more expensive than the Morel EM1308 (145€) so it will be interesting to see how it stacks up against that. The morel looks like it goes a little lower but is less efficient. Hopefully someone will do a comparison soon.
Hmmmmm......
There is better options, Morel cam 558, Morel mdm 55, Visaton G50 ffl, Visaton dsm 50 ffl..., Morel tm 4055-8 gives you tweeter/midrange combo
btw. I'd like to finally see the measurements of the Visaton dsm 50 ffl because it can be one of few very underappreciated transducers.There is better options, Morel cam 558, Morel mdm 55, Visaton G50 ffl, Visaton dsm 50 ffl..., Morel tm 4055-8 gives you tweeter/midrange combo
You can "feel" what they may measure like by looking in Visaton's Boxsim. In fact there is nothing that can go wrong with any of Visaton's mid domes. People are simply unsure because they act under influence of marketing schemes and at present nobody is speaking in favor of any of these units.
- Munich 2019 -Sb Acoustics room
