Mtx ta92001 distorted output.
Ok replace tl494c pwm controller. inductors are not buzzing anymore but still not getting the two LEDs by the RCA inputs to light up and still have 24 volt DC output on the speaker terminal. Got my oscilloscope in now. ready for some real testing
Here's the readings it power on then With it powerd off.
That should have disconnected all drive from the opto-couplers. You can confirm by measuring the DC voltage between the diode pins of the couplers. They should remain at 0v when the amp is on.
One of the opto-couplers may be leaking. You need to remove them AND install a jumper between pin 5 and 6/7 on each one. Don't apply power without the jumper. Do you still have significant DC?
All opto-couplers show on pin 2&3 .243 volts but it fluctuates between .243 and 0 volts. I set my oscilloscope to diode function.3 of the 4 opto-couplers on pin 2 and 3 show 0L. One of the opto-couplers shows 0.005. I will be pulling the opto-couplers out that show 0L out now and jump pins 5 and 6/7
