MTX JH1200 repair
Good evening. Please help me with the repair of Mtx jh12000. He came to me without many complete sets and I am trying to restore them. Can anyone know what resistors should be in the allocated places? And another problem is + -15v. put new lm317 lm337 but they heat up even without load, 70 volts come to their input after tip29 tip30 ..
Tip29c and Tip30c I replaced with bd911 bd912 Did I do it right? I could not buy original spare parts in our city. I also attached a photo of the pulse on the shutters of the power supply, is everything good there? Thanks in advance to everyone who responds ...
I installed new operational amplifiers tl074 tl072, a sound appeared and after 5 seconds everything burned out .... I evaporated them .. as I understand it, these + -15 are needed to power them ... but even without them lm337 and lm317 are hot .. Tomorrow I will take a photo ... Maybe there is a circuit of this amplifier? are the resistors between the base and the collector on bd911 and bd912 correct? I was embarrassed that one had 3.32 Kom and the other had 12Kom
R4 is a 100 ohm. Marked 1000.
What do you mean that the 317/337 have no load?
What is the voltage on all 3 terminals of each regulator?
It's normal for voltage regulators to heat up.
Are the TIP transistors generally clamped to the heatsink?
Try a different translator (try several). Convert from your language to English and then back to your language to see which translator gets the closest to the original statement after the second translation.
Just probed tip29c .... After removing tip29c tip30c lm317 lm337, the cooler started to rotate as expected. The volume level and heating of the thermistor with a soldering iron did not give a result. Maybe there should be zener diodes instead of diodes?
