MTX 81000D no high side gate drive
GD folks,
Got A MTX 81000 in, good old school. Both R474, 475 were open. replaced both with new, powered up ok. good rails but no reg LV supplies. Replacing both with 1 ohm 3W through hole parts, the reg LV presented themselves.
Moved onto the class D section, all output FETs (SSP45N20 appear to be original) tested ok.
After replacing both optocouplers, the NE5532, and Q239(was shorted), I have 20.33vdc and 19.33vdc across pins 5 and 8 of each optocoupler respectively.
With a 55hz sinewave in, I have audio at pin 1 of the NE5532, and a sqwave at pin 7, at the gates of the output FETs, i only get LS and and very faint HS pulses.
D260, measures 19.52vdc across it.
Below are a couple of pics for pins 1 and 7 of the NE5532 and the gate drives at the HS and LS FETs.
Anyone got any pointers on how to proceed?
Arite, just did, while I realised I messed up pulling a data sheet for it.
Replaced it and now I have audio at the speaker terminals.
However, I notice around 6v and under, output at the speaker terminals, the wave is heavily distorted, and the final inductors crackle off, if I increase the input signal to where the output goes above 6v, it produces a clean sinewave.
The inductors, don’t get warm with the testing I’ve done so far, and the final caps appear to look as if someone has pressing their tops in.
