Im in the process of bringing this amp back to life. The modle i have is the 2300x Black heatsink with gold lettering.
I have a couple questions
Wondering what is a good power supply fet for this amp?? Since the fets are missing.
There is a resistor thats to burnt to tell the value wondering if anyone knows the value of R429 located in front of the rectifier.
And what transistor goes in Q220's spot since its missing
The resistor thats missing in mine is the 1 closet to the cap in the row with 4 resistors. It looks like a 22.1 ohm resistor from what i can see is this correct?
Also i have another 2300 amp but the board is totally different.
The one im repairing is the 2300x and the other one i have is a thunder 2300 is there a difference in output of theese amps or about the same?
I also noticed this amp has the same problems as the other 2300 i have,The 1N4148 diodes by the output transistors are shorted is this a common problem when the outputs go?
Also im gonna be fixing alot of problems in the output section since i found someone tryed repairing this amp themselfs and had 540's on 1 side for the outputs and irfz48's on the other side , Gotta love it
- General Interest
- Car Audio
- MTX 2300 X
